07-11-2020, 03:30 PM | #1 |
adhesive removal- dash
Looking for recommendations to get adhesive off of the dash, previous owner had a carpet mat on the dash and had it Velcro or glued on, dash is in good shape but has big strips of adhesive all over it. What can I safely use to get that off without ruining the dash?
07-11-2020, 09:35 PM | #2 | |
Re: adhesive removal- dash
https://googone.com/howto/blog/does-...-work-on-that/ It may affect the color. |
07-11-2020, 09:41 PM | #3 |
Spray brake cleaner on a cloth, test in unseen area. If ok, wipe away..........
07-12-2020, 10:36 PM | #4 |
another vote for goo gone. I believe brake cleaner will damage paint.
07-13-2020, 06:10 AM | #5 |
Iv'e used Varsol ( paint thinner ) on stuff with good results
07-13-2020, 11:31 PM | #6 | |
I all so used cup hot water and plastic razer blade in the high heat direct sun light lots of elbow grease and what energy work out.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
07-14-2020, 07:10 AM | #7 |
Normal automotive vinyl cleaner.
Hot soap and water. Rubbing Alcohol. |
07-18-2020, 02:37 PM | #8 |
Thanks for the tips, I'll try some of these options and post the results for everyone
03-22-2021, 05:49 PM | #9 |
Have you had a chance to try out any of those products on your dash?
I’m in the same boat as you. Old glue all over the dash. |
