11-29-2021, 05:58 PM | #1 |
Post Whore
Wood floor replacment bolts and metal strips.
AWhen I replaced the wood floor in my Suburban I found that the 5 smooth top countersunk bolts (1/4-20 Plow Head bolts) that are across the rear of floor are not available.
These fasteners are usually rusted and have a tendency to twist in two when removing. I ended up modifying the closest bolts I could locate on my lathe to make replacement bolts. (Quick word of thanks to Richard 2717) These are a close but not perfect replica of the originals. The biggest difference being the countersunk area on the back of the bolt is smaller. The downside of this may be a reduction in how much torque the bolt will take before the head would deform. I had no problems with this when I installed them in my floor. The bolts have been sprayed with cold galvanizing paint. I have 10 sets. I also have 2 of the metal strips that go across the rear that I had made. Mine was too rusted to reuse. These pieces are not drilled and countersunk at l present but I will do that before shipping. The reason I haven't done it yet is that when I did mine I noticed the holes were not consistent in their spacing. I would need to know the specific spacing measurements from your Suburban or that you would be okay with having to drill additional holes in your truck to get the bolts installed. Here is a link to the floor replacement part of my repair thread. It goes on for several pages with a couple of detours before completion. https://67-72chevytrucks.com/vboard/...698377&page=20 Pricing for the bolts is $25.00 for a set of 5 shipped. (As of 10/23) Pricing for a rear strip is $45 plus the shipping. I also have one factory front hold down strip with extra holes drilled in it for $25 plus shipping. There are no more of the #1 bolts (See post #9) available at present. (12/23) More information on the bolts. http://67-72chevytrucks.com/vboard/s...d.php?t=721207
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-03-2024 at 02:27 PM. |
11-29-2021, 06:03 PM | #2 |
Post Whore
Re: Wood floor replacment bolts and metal strips.
Photos of the finished strip I used in my Burban.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-30-2021, 02:35 PM | #3 |
Equal opportunity joke ofender
Those turned out nice
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-30-2021, 11:55 PM | #4 |
Post Whore
Thank you Richard, for everything.
01-19-2022, 05:53 PM | #5 |
Post Whore
Additional photos of the countsink or dimple process. 1st one is the die I made to do the job. 2nd one is test fitting in the factory piece. 3rd is the testing program.
01-22-2022, 08:48 PM | #6 |
I like your punch and die setup
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-25-2022, 07:18 PM | #7 |
Post Whore
Thank you. It was an enjoyable little lathe project.
04-10-2022, 11:01 AM | #8 |
Post Whore
Bump to the top.
08-08-2022, 02:32 PM | #9 |
Post Whore
I now have 4 sets of 12 of the # 1 bolt in the first photo below. They are not an exact match to the ones the factory used (Photo 3). The factory ones had 7/8" head with a 1" long 3/8 shaft.
These have a 1" head with a 1- 1/2" 5/16" shaft. (Photo 2). They do however have the same shallow dome head as the factory bolts did. Visually They would be amost indistinguishable from a factory bolt once installed. Modern carriage head bolts have a much smaller head with a rounder dome head or the other option would be a head with a slot and no square shank under the head. Photos 4 & 5. I will include 12 of these for no charge with an order of the rear bolt set.
08-14-2022, 12:22 PM | #10 |
I will take a set. Thanks.
08-15-2022, 12:35 PM | #11 |
Post Whore
PM sent
08-24-2022, 05:39 PM | #12 |
Post Whore
Payment received and package posted. Tracking number sent via PM.
Thank you and good luck on your project.
08-24-2022, 11:53 PM | #13 |
Thanks for the hardware.
09-08-2022, 09:44 AM | #14 |
I’d take a set of bolts and front and rear mounts strips if they’re still available
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
09-08-2022, 03:53 PM | #15 |
Post Whore
Yes they are available. Forward your zip code so I can figure the shipping costs.
For the rear strip I will need a measurement from the drivers side to the passenger side in order to correctly place the countersunk holes. There needs to be a 1/16" gap between the side flange and the rear piece on the drivers side. (Photo #1). Don't include that 1/16" in the measurement of the hole layout. Then record the center of the hole measurement as you move from the drivers side towards the passenger side. For example #1 hole at 2 5/16" #2 hole at 9 3/4" #3 hole at 15 13/16" and so forth 1 through 6. See photo #3 The last hole (circled in orange I will leave to you to drill as there are too many variables to allow me to drill it accurately. (As I found out doing mine. Last photo. ). You will need to either square the hole as I did or drill it over size so the square part of the carriage bolt will pass through. See the link for further information (Post 542 specifically but lots of floor information on other pages) and by all means ask questions if I've confused you. http://67-72chevytrucks.com/vboard/s...698377&page=22 P.S. the front strip is an original one shown in the #2 thru #5 photos in first post. It has extra holes courtesy of a PO.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-08-2022 at 03:58 PM. |
10-03-2022, 08:21 AM | #16 |
It’s tough to see but the first photo is the bolt location on the drivers side.
10-03-2022, 01:01 PM | #17 |
Post Whore
When I replaced the wood in mine I got the impression the holes across the back were randomly placed. Your's certainly supports that theory.
From your picture it looks like the outside strip on yours runs farther back than mine does and it looks like there is a carriage bolt near the end. Mine is a 67 Fremont truck. Frankly I would be surprised if all Suburbans were the same across all years and plants. When I had the strips folded I didn't make them with any extra length. (I know, what was I thinking?) That leaves a us some options. One is I go have longer strip cut and bent (Which I'm sure will increase the cost. UGH! It's been several years since I had them made.) Or I could put the first hole where mine is and you would have to drill a hole in the lip underneath to match and then I would match the rest of your holes. Or I could try and match the first hole with the minimum amount under the side strip on drivers side and hopefully there would be enough on the passenger side to get a bolt through. Let me know.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-03-2022 at 01:08 PM. |
10-04-2022, 09:25 AM | #18 |
Post Whore
Confirming the measurement plan.
10-05-2022, 12:52 PM | #19 |
Junior Member
I sent a Pm. Thanks!
Posted via Mobile Device |
10-05-2022, 01:00 PM | #20 |
Post Whore
11-18-2022, 03:16 PM | #21 |
Post Whore
Payment received and parts shipped.
11-30-2022, 02:34 PM | #22 |
Received the parts. Thanks again.
03-11-2023, 11:45 AM | #23 |
Post Whore
Bumping to the top. Parts still available.
07-19-2023, 11:30 PM | #24 |
Post Whore
Bump for summer project.
10-06-2023, 09:19 AM | #25 |
Post Whore
Bump up for winter project.
