02-13-2022, 03:35 PM | #1 |
Np205 linkage
I purchased an ORD np205 for my 4l80 swap and the shift rails look to be in a different position than my stock 205. Does this require the newer s shaped linkage bracket that connects the two? The bar is the stock one off my original 205 but it will not fit. If this is the case will it still work with my stock shifter? Thanks for the help in advance.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 02-13-2022 at 04:24 PM. |
02-13-2022, 07:21 PM | #2 |
Re: Np205 linkage
I belive ot is Chris at ORD who is very helpful. Maybe give him a call tomorrow and see what he says?
02-13-2022, 09:34 PM | #3 |
Re: Np205 linkage
You just need the L shaped link plate.
02-13-2022, 10:14 PM | #4 |
Re: Np205 linkage
I ordered the plate today. I’m thinking that’s what it is. Just hope it fits my stock shifter.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
02-19-2022, 08:34 PM | #5 |
Re: Np205 linkage
Well the new bar fits but now the link on the shifter seems to be too short. So I’m making a Hiem joint link. I believe the shifter is clocked differently on a newer transfer case. Since I don’t want to change my shifter this will be my only option.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 02-20-2022 at 07:17 PM. |
02-24-2022, 11:09 PM | #6 |
Re: Np205 linkage
My solution.
02-25-2022, 05:19 AM | #7 |
Re: Np205 linkage
Nice solution, did you make the stud for the heim joint......
Are you using a twin stick, or is that a stock configuration Haven't seen any updates on your build thread
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-25-2022, 06:29 PM | #8 |
Re: Np205 linkage
Yes, I made the stud, I bought everything from McMaster Carr. All 5/16 316 stainless. There’s a plastic bushing in the shifter. It literally fits like it was from the factory and is more solid.
It’s a stock shifter. I don’t want the twin stick as this is more of a asphalt and dirt road queen. I’m too afraid to offroad it much. I’ve been so busy I’ve only been chipping away here and there. I did install some exhaust. I’ll have to update.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 02-25-2022 at 06:38 PM. |
02-25-2022, 08:10 PM | #9 |
Re: Np205 linkage
You should put a lock nut on the adj threads so the threads are locked down tight and not move around. looks nice
02-27-2022, 05:29 PM | #10 |
Re: Np205 linkage
I thought about that but I don’t see it moving much. There’s only a few degrees of movement until it stops. I ordered lock nuts but they sent left hand threaded nuts so I couldn’t use them.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 02-27-2022 at 09:34 PM. |
