Old 11-13-2023, 02:49 PM   #1
kwmech
Suburban rwal
So I upgraded axles and brakes on my 91 Suburban to a full float 14 bolt rear and a Dana 60 front. The front axle got a conversion to 3/4 ton rotors. Still have the 1/2 calipers on it. Have a 3/4 ton master (not installed yet). Issue is a spongy pedal and I'm leaning towards the RWAL dump valve not working quite right. NO bleeder on the valve. I previously had issues on my other Suburban with the same issue. I am considering removing/bypassing the dump valve. Yes everything is adjusted correctly and have bled the system thoroughly. Any thoughts?
Old 11-13-2023, 03:52 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Suburban rwal
Deleted.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-13-2023, 05:29 PM   #3
nvrenuf
Re: Suburban rwal
My '91 Blazer had RWAL, I removed it when I swapped in 1 tons.
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 11-13-2023, 08:39 PM   #4
kwmech
Re: Suburban rwal
Was the difference noticeable?
Old 11-17-2023, 07:55 PM   #5
kwmech
Re: Suburban rwal
Made quite a difference in braking. Have a real brake pedal now. Couple of pics
Old 11-17-2023, 07:59 PM   #6
kwmech
Re: Suburban rwal
Left over parts
Old 11-22-2023, 11:19 AM   #7
kwmech
Re: Suburban rwal
May have to re-do a little bit. I think the stock combination valve is a weak link with the elimination of the dump valve. Pedal is way better, but not quite there
