01-18-2004, 08:47 PM | #1 |
What year door?
Can anyone tell from this picture what year door this is?
Thanks |
01-18-2004, 08:51 PM | #2 |
Active Member
door ID
I would say that its not a 1972.
So it would have to be a 67-71 |
01-18-2004, 09:03 PM | #3 |
Forgot to add that it had 8 of the white plastic tabs that held the door panels in. Here is a pic of the door panels.
Front |
01-18-2004, 09:04 PM | #4 |
back
01-18-2004, 09:12 PM | #5 |
Project Junkie! Fishing Poor!!
If those door panels came off of them they would be 72 doors. The way to tell for sure is if there is a screw or screw hole below the vent window. If there is then they are 72s if not they would be 67-71. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
01-18-2004, 09:27 PM | #6 |
I dont see a screw or screw hole unless I missed it
01-18-2004, 09:43 PM | #7 |
The door is definitely a 67-71. The door panels are 72 though.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-18-2004, 10:54 PM | #8 |
So door panels from a 72 can be put on a 67-71 door using the white plastic clips. How would you install a 68 door panel? Whats needed?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-19-2004, 12:58 AM | #9 |
If that door panel fits the window regulator crank opening and matches up everywhere else it is a 72 door that someone has cover the vent support screw. The panels will not work from a 72 to a 67-71 door. The regulator crank sits futher forward on the 72.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach (upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL) 71 Custom Deluxe 350/350 Tilt/PS/PB 00 Blazer |
01-19-2004, 01:30 AM | #10 |
the 72 window regulator post and door handle post are longer than a 67-71. you have to swap the guts to make that door pannel work on the earlier door.that pannel is 72. you can put an earlier pannel on that door, the posts will stick out or change them out for 67-71 reg and door handle wooha. im pretty sure that all aftermarket doors are that design without the "72 screw" mounting hole for the wing assy, but i could be wrong.
yeah, but how's it wheel? |
01-19-2004, 01:46 AM | #11 |
Probably better off just getting new doors
01-19-2004, 03:47 AM | #12 |
I can definitely tell that it is NOT a 67 door. ( vent handle is obvious ) but it looks like a 71-72
01-19-2004, 05:19 AM | #13 |
AKA Phillip Johnson, AKA BANNED!
It is NOT a 72 door. All others are the same. Any door panel will fit with a drill and some screws. since it isnt a 72 door, you shouldnt have to change the regulator, unless someone put a 72 inside it. Then you are only talking about 1/4 inch longer shaft on the window crank. not a big deal if its just a driver and not a show truck.
01-19-2004, 02:57 PM | #14 |
From Elk Hunter' post:
"the 72 window regulator post and door handle post are longer than a 67-71" Does this refer to the window regulator itself being different in 72 vs. before? I bought a NOS left side regulator for my 72 but didn't install yet. Now have a 71 where I will want to put it. Is the regulator the same for 71 as the one I got for 72?
72 C20 3/4 Custom Camper 94 Roadmaster Estate Wagon |
