06-05-2008, 12:21 AM | #1 | |
Re: Dropmember Rear 63-72 Spy Pic
Also, I have gained enough experience with UPS to understand that they do not take it easy on packages... especially the heavy ones! After dealing with torn box issues in the beginning, I have since switched to double boxing all components (two double walled boxes, with hardware and other pieces boxed inside) ... a little more spendy for me with the custom sized boxes, but I haven't had a "lost" component since.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-07-2008, 10:15 PM | #2 | |
1990 Dodge Ram D250 Cummins |
06-12-2008, 12:05 AM | #3 |
OK guys... my OCD kicked in over the past week, and I ended up modifying the notch in order to make installation MUCH easier. The new notch design is a three piece... the main notch will slide over the rails, it will get bolted in place, the bridge then bolts in place, then the frame section gets cut-out, and finally the inner bridge cap/supports get bolted on. This thing is a beast...
06-12-2008, 12:06 AM | #4 |
more...
06-12-2008, 12:37 AM | #5 |
Ya better take that puppy to the Vet cause it looks SICK!!!!!!!!
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
06-12-2008, 02:56 PM | #6 |
A guy with a truck
Will the inner bridge cap be one piece? Would you have a problem towing with this setup?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-12-2008, 03:01 PM | #7 | |
As for towing... I would not recommend towing with frame that has been notched.
08-13-2008, 02:21 PM | #8 |
PITbut
08-13-2008, 02:52 PM | #9 |
A guy with a truck
Will the notches be modular- say if someone wanted to change to a larger notch later for taller tires/wheels or just wanted to go lower- would it be a bolt-in swap?
08-13-2008, 03:13 PM | #10 |
The notches are a modular design. If one originally purchased a 26" notch and later decided to switch to a 32" notch, they would just need to unbolt the original notch, and bolt-in the larger one (sounds a lot easier than it really would be). All the drilled mounting locations are universal for the notches.
08-14-2008, 11:00 AM | #11 |
3DrDwn--the 'burb not the band
I'm sure Nate will correct me if I'm wrong ( it happens ) but the last specs I got was the rear DM topped out at a whopping 12.5" above the top of the factory rail. I believe tyhe actual quote from Nate was " Your plywood floor is ready for the fire pile"
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
08-14-2008, 02:29 PM | #12 |
The biggest notch I make (will lay a 32" tire) sits 12.5" above the frame-rail at the axle center-line, with the bridge piece bolted on. People ask... how much do I have to "trim" the bed floor? It's best to remove it and start over.
