Old 07-03-2009, 04:20 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
gonna find out my rear end ratio....
i dont have a tag on the diff bolts..
if i take the cover off to read the ring gear..will i be able to find it? or am i better off to spin the whels and count the driveshaft rotations? and how much does it cost to rebuild a rearend? (roughly)
thanks!
John
1999 Toyota Tacoma 4x4
Old 07-03-2009, 04:27 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: gonna find out my rear end ratio....
Pop the cover and read the ring gear. Turn it around until you get to the numbers and wipe the oil off of them. There will be two numbers separated by a colon. Divide the first number by the second and you will have your ratio.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-03-2009, 04:35 PM   #3
oldblue1968chevy
i got 1 tire jacked up (not posi) ok i turn the tire count the driveshaft truns and time that by 2 right?
im confused ima go out there do it and write it down then post it here lol thanks
ok thats what ima do to my donor rearend thanks! will any oil leak out?
John
Old 07-03-2009, 04:45 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
What you do is to turn the pinion yoke (driveline) exactly one time and count how many times the tire goes around. It's actually a pretty darn accurate redneck way of finding the ratio. Chalk or mark the tire somehow.
If it's goes around 3 1/2 times, it's about a 3.50
If it only goes around a little more than 3, it's a 3.07 or 08
I like it when they go around 3 3/4's times cuz that's your 3.73
and so on......
prostreetC-10 is offline   Reply With Quote
Old 07-03-2009, 05:00 PM   #5
oldblue1968chevy
30 56
30 being the tire spins
56 being d shaft
i came up with 3.73 is this correct? thanks goin into the weeds with the snakes to calcualte the other rearend...
John
Old 07-03-2009, 07:25 PM   #6
I`m not sure,did you spin it that many times?
Did you do what TX Firefighter suggested.It`s downright fool proof.YES,oil will leak out,if there`s oil in there.Get some fresh lube,put a pan under there,and start taking the lowest bolts out all the way.It will start draining.Go ahead and start taking all the others out while it`s draining.If draining is slowed down you can pop the cover off with care.It can take a long time to stop running/dripping.Check the condition of the lube and get back to us.
Old 07-03-2009, 07:36 PM   #7
prostreetC-10
My Carbon Footprint
Originally Posted by oldblue1968chevy View Post
30 56
56 being d shaft
Not sure K and I know what you are talking about. Just what exactly is the 30 and what is the 56?
Old 07-03-2009, 07:43 PM   #8
oldblue1968chevy
uhh dang lol i forgot
its been a few hours..but i think 30 is tire spins and 56 is d shaft spins...this is before ANY MATH IS INVOLVED
John
Old 07-03-2009, 07:48 PM   #9
Big-Blue
Big-Blue's Avatar
Here's a shot of my 4:10 rear end.
The text reads, 7 3 70 DANA 30360 A306 41-10
I am guessing the first three are the build date, the next the model and material and lastly the ratio.
Big-Blue is offline   Reply With Quote
Old 07-03-2009, 07:48 PM   #10
prostreetC-10
My Carbon Footprint
You are making it too tough. You just need to mark the tire and spin till the driveline U joint makes one complete circle and at the same time count how many times the tire goes around. You will end with a fraction on the last spin.
Old 07-04-2009, 12:15 AM   #11
twotrucks
Junior Member
The numbers represent the number of teeth on the ring gear and the pinion gear.
twotrucks is offline   Reply With Quote
Old 07-04-2009, 12:17 AM   #12
oldblue1968chevy
So do my numbers add up right?
can somebody tell me?
John
Old 07-04-2009, 12:37 AM   #13
Aunt-Jemima
Where did you get your numbers from? The gear or did you spin the tire that much?
1969 c20 350/th350(shift kit) A/C cab custom headers and exhaust
1972 c10 307/th350 (wrecked) possibly selling
Aunt-Jemima is offline   Reply With Quote
Old 07-04-2009, 12:41 AM   #14
Aunt-Jemima
And isnt it how many times the drive shaft spins to make one tire rotation?
Old 07-04-2009, 12:56 AM   #15
prostreetC-10
My Carbon Footprint
Too many Beers......................YES!!!!!!!!!!
I was bass-acwards!!!!
I can say though that that pinion doesn not have either 30 or 56 teeth!!!!
Are you counting the spider gears??? The pinion you can barely see because the carrier covers it up. If you took the cover off, just look at the last numbers on the ring gear like "big blue" showed us.
Old 07-04-2009, 01:04 AM   #16
Aunt-Jemima
haha It happens prostreet
Old 07-04-2009, 01:57 AM   #17
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
30 56
56 being d shaft
I think I understand what you did, it is the same as prostreetc10 said except you only lifted one tire and you turned the driveshaft enough times to make for round numbers. so if you turned the yoke 56 times and the tire turned 30 times then you divide 56 by 30 which equals 1.867 but the ratio is actually twice that because the spider gears cause the tire to rotate twice as fast as when both tires spin, so you have to multiply 1.867 by 2 which equals 3.734, so I'm pretty sure the rear is a 3.73. Hope this makes sense
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-04-2009, 05:59 AM   #18
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
Old 07-04-2009, 07:02 AM   #19
combustion
haha signature material ^^
combustion is offline   Reply With Quote
Old 07-04-2009, 09:40 AM   #20
Tx Firefighter
No, on a 1 legger rearend, you must spin the tire two times. You must double it. For instance, you spin the tire twice, you will find the pinion spins 3.73 turns.
Or, you can buy 2 quarts of lube, a tube of silicone, and a can of crab spray cleaner and do it right. Who knows how old and nasty the fluid in there is. You don't want you bearings running in dirty grease do you ? Do it right. It won't take 15 minutes.
Old 07-04-2009, 09:52 AM   #21
oldno7
oldno7's Avatar
This is sorta funny. I think you should buy a new ring and pinion and then it will be what you want it to be
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 07-04-2009, 09:53 AM   #22
prostreetC-10
My Carbon Footprint
Probably the easiest way to find out what you gear ratio is.....is to pull #3 and #7 spark pull. Take the divided gap of both and times it by your carb CFM. Then you take (in inches) the distance from the front of the INSIDE of your bed and measure back to the full cooler of beer. Now....add up the EMPTY beer cans that are still cold. Take Pie R Squared and times that by the model number on your left front head light. That will usually give you the gear ratio of your rear end down to about +/- .00000000021
Old 07-04-2009, 09:55 AM   #23
oldno7
oldno7's Avatar
prostreetc-10 You forgot to and the number of lug nuts you have
oldno7
Old 07-04-2009, 10:03 AM   #24
oldblue1968chevy
jacfourteen, i hope you understand, and you others...sorry for my stupidity lol........does anybody else agree with jacfourteen
John
Old 07-04-2009, 11:43 AM   #25
oldno7
oldno7's Avatar
oldblue1968chevy Sorry this got out of hand. Thier's 2 parts to this, 1st you just asked a good ? about how to determine rear ratio's. Then the other part where if you ask the same ? to 15 diff. people you get 15 diff answers. That's where it gets funny. So it's got nothing to do with stupidity on your part. There are many diff personality's on here most good and some jerks. Happy 4 oldno7
oldno7
