09-11-2012, 12:56 PM | #1 |
PHOTO WANTED - Stock Throttle Linkage
Hey everyone,
I know this has probably been discussed before, but I wasn't able to find exactly what I needed with the search function.. I need a picture of a stock throttle linkage setup... preferably a V8. I just installed a 327 in my '56 stepside. The PO installed some piece of junk aftermarket linkage that was good for nothing. I purchased a new V8 stock linkage and am hoping to be able to use that... problem is that I cannot seem to figure out how it all mounts up. Can someone provide a picture or at least point me in the right direction? Thanks!
Will Tucker http://www.willtuckermusic.com 1956 Bel Air 4 Door Sedan Project 1956 C3100 Stepside Truck Project |
09-11-2012, 02:24 PM | #2 |
Re: PHOTO WANTED - Stock Throttle Linkage
Here is mine, I do not run a pedal on the inside. I made my own rod between the linkage and carb. The HEI made it interesting but doable!
09-11-2012, 03:22 PM | #3 |
i think orrieg's linkage is modified to have a shorter stroke
i just sold this to a member here
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-11-2012, 03:22 PM | #4 |
09-11-2012, 04:25 PM | #5 |
I appreciate the responses, guys. The linkages being posted are extremely similar to the setup that the PO did. The thing is that I would really like to retain the stock pedal by using the stock linkage. The one like this:
09-11-2012, 06:34 PM | #6 |
In photo:
Black rod in RH rear extends through floorboard and seats in matching socket in pedal. Flat bellcrank lever attached to black rod extends up firewall behind LH valve cover. Bracket with two holes bolts to firewall. Long rod extends forward from bellcrank to attach to LH side of carb. If I can make ASCII art work... Code:
Carb ------------ F \ I _\__ R |_\_| E \ W \__A__ \ L \ Pedal L \ Last edited by 1project2many; 09-11-2012 at 06:43 PM. |
09-11-2012, 07:10 PM | #7 |
Attached is the diagram from the v8 rpo in the FAM. 55-57 had this type. 58thru the 60 had the one like I posted. It came out of a factory V-8 62 c20. As I said I do not use the pedal that pivoted at the floor and snapped into the ball on the end of the shaft because I wanted to keep the floor clear. In my opinion the later one is simpler and cleaner, but if you want absolute stock start looking. If you do not want to use stock another option is to use the mid 70's truck style that bolts to the fire wall from the inside and uses a pull cable thru the fire wall. It also keeps the floor clear.
09-11-2012, 07:11 PM | #8 |
09-11-2012, 09:05 PM | #9 |
Maybe these will help. A friend of mine was trying to figure out how his attached also so I snapped these of another friends truck 4th picture.
05-23-2014, 10:40 AM | #10 | |
I wanna start getting this thing on the road as soon as I can and this is a little hick-up I gotta get done. |
05-23-2014, 10:49 AM | #11 |
Your linkage looks like one for an AD truck - not a TF
05-23-2014, 11:02 AM | #12 |
FWIW, after I wired the HEI I had to modifiy the firewall end of the throttle rod.
http://67-72chevytrucks.com/vboard/s...&postcount=943
05-23-2014, 11:51 AM | #13 |
Pics of stock V8 throttle linkage in my 55.2 3100. Gas pedal is from '57, I think, and PO used cable instead of rod to hook up carb, it works so I haven't changed it out yet.... "Don't fix what aint broken"
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
05-23-2014, 12:10 PM | #14 |
Will, looking at the pic of the linkage you have, the rod that the pedal presses on looks like it is nearly straight to the bar that the carb rod attaches to. As you cn see on mine, there needs to be a angle between the two for the linkage to work. My assembley is welded together, can your rod be rotated?
05-24-2014, 12:23 AM | #15 |
I bought the same linkage you did, but haven't hooked it up yet. I did notice there is two factory holes on the firewall that match up with the plate that is centered on the linkage. My truck was originally a 6 cylinder. From what I can tell you bolt or screw the plate to the firewall and the short rod sticks through the original hole under the pedal.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
05-24-2014, 03:41 PM | #16 |
I think you have what capnduane showed minus a piece or two. That works with a rod going though the firewall which creates a nice air leak when the boot around it gets worn. Most Task Force trucks I have seen run the other setup that the guys showed which may actually be a six cylinder setup but seals the firewall quite well. And it works good too.
05-24-2014, 03:50 PM | #17 | |
05-24-2014, 04:51 PM | #18 |
OrrieG, I was adressing Will, the OP of this thread. The throttle linkage he posted a pic of is very nearly the same as the one in my truck.
05-25-2014, 11:00 AM | #19 |
I have used a couple of those original type kits. It is confuseing because the way it comes is not the way it fits in. You have to take it apart & figure it out. It fits & works real good once you get it right.
05-25-2014, 10:40 PM | #20 |
Hello ChevroletWT. My truck has the same linkage as what you posted. Stock gas pedal. The only part that goes through the floor is the short arm that pops into the back of the pedal. Its hard to see in the first photo but you can see where it goes through the floor. Hope that helps.
Earl aka Clarance J
You have to have patiences or you'll be one. |
