Old 06-02-2013, 09:20 PM   #1
meatwagon83
meatwagon83's Avatar
dealing with the extra weight if a diesel
while going fron a big black to a diesel what did you do todeal with the extra wieght? from what i understand a cummins weights almost twice as much as my big block and i want to know how much it will affect ride hieght, right now i have the hd moog springs in it but i will be converting to 4wd at the same time i do the diesel conversion and im wanting to put 4 inch lift springs on it
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 06-03-2013, 10:46 AM   #2
Ackattack
Ackattack's Avatar
Re: dealing with the extra weight if a diesel
Here's what I did (not the easy way, btw)
I also converted to 4wd by using the dodge dana 60 in the front. I went ahead and used the dodge coil springs as well since they made to carry the cummins anyways. This required a lot of cutting, thinking, cussing, and work. Leaf springs would be A LOT easier
For leaf springs, I think I would call a spring shop and get some input from them.
Ackattack is offline   Reply With Quote
Old 06-03-2013, 03:36 PM   #3
legendman
legendman's Avatar
I went from a 6.2 to a 6bt, front springs didn't move much.
I figure the 6bt is about 300lbs heavier fully dressed.
I don't think a 6bt weighs twice what a bigblock does.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 06-03-2013, 04:52 PM   #4
cAlvis165
cAlvis165's Avatar
I'm finding 685 lbs. for a fully dressed 454 (including cast iron manifolds) and 980 lbs. for a ve pumped 12v 6bt. The 12v weight includes 47rh adapter plate , flexplate, starter, vacc/power steering pump, a/c compressor, altenator, hx35 turbo, oil filter full of oil, 12 qts oil in the pan, diaphram lift pump, fuel filter, and crew cab`s motor mounts, no fan or fan clutch. So not quite as bad as you would think. 300+/- lb. difference.
Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 06-03-2013, 04:58 PM   #5
legendman
legendman's Avatar
Chad
Nice info.
So adding a 6bt would be quite a bit less than say adding a old school Fisher 9 foot plow, a lot of K30s and C30s back in the day were earning their keep plowing snow.
Old 06-03-2013, 05:01 PM   #6
Mattman2010
Mattman2010's Avatar
I used some 4" rough country springs and so far the cummins doesnt seem to squat much, but I have not had the truck all back together yet. And my frame is twice the weight of the stock frame.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 06-03-2013, 07:27 PM   #7
cAlvis165
cAlvis165's Avatar
Originally Posted by legendman View Post
Nice info.
Good point!
Old 06-03-2013, 09:22 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
On the 89 V20 Suburban I did last, it had Skyjacker or rough country 6" lift springs. They hold the weight fine. After 2 months of towing and or bouncing the springs did settle about an inch. So take that into consideration on the lifted trucks. In other chevy leaf spring trucks, I haven't had any real issues with heavy duty leaf springs. In other words, not a 2 leaf spring up front.
Ryan
1969 Chevy milk truck
Old 06-03-2013, 10:21 PM   #9
meatwagon83
ok thanks, it seemed like i read somewhere that a cummins was 1200 lbs, guess i got bad info, i did plan on useing the 4 leaf front springs so that should take care of it!
Old 06-03-2013, 10:57 PM   #10
yousesteers
On mine I left everything stock. I am going ot put on new springs and shocks but have been driving it for 2 years
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 06-03-2013, 11:19 PM   #11
legendman
legendman's Avatar
A P pump weighs a bit more than a VE pump so that could be the difference
Old 06-04-2013, 05:26 PM   #12
Dieselwrencher
A P-pump 12v with turbo and full of fluids is 1150lbs. That's an a/c comp, denso starter and alt. It can weigh more or less pending any other accessories.
Ryan
Old 06-08-2013, 10:40 AM   #13
ryanroo
ryanroo's Avatar
4" tough contry springs in mine(that will be replaced with airbags and links as soon as Ryans longhorn gets done) and they handle the weight fine for the current stationary status of the truck. they doo squish a bit less than an inch when you sit the cummins and nv4500 in the frame.
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
