Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-14-2015, 01:31 PM   #226
jaros44sr
jaros44sr's Avatar
Re: 70 Blazer Frame Off
Originally Posted by IronCanine View Post
OK Jim,
I looked at your picture...and I hope I'm on the same page with you. What I see is the retaining washer, which you should be able to just pick off. Two spindle or lock nuts should be on either side of that. One of those nuts should have a small dowel that engages the holes in the retaining washer. The Lisle part numbers you have look like 4WD spindle nut sockets...you definitely need one of those to break these down (and what I would assume you had to use to take the first lock nut off if it was assembled in the correct order). I got my socket off the rack for $20 from AutoZone (OEM brand, part #25072A), but everybody's got them I think. That socket engages the lock nuts, not that retaining washer.
Here's a good hub breakdown link...it's a Jeep Dana 44...but the sequence is the same:
http://www.pavementsucks.com/tech-article-14.html
If you're talking about the locking hub assembly themselves...I didn't have to do any breakdown there...I slid the old Warns out and the new Warns in.
I hope this helps.
Thanks, ok, you were on the right page, i was not! In fact i had the right tool, just didn t remove the retaining washer, picked that off, and now at the next retaining nut. PO didn t assemble with all the pieces. Luckily, i have a 4X4 shop around the corner, and he has all the OEM parts that were missing, but first, i believe i have a cross threaded nut
Starts to spin freely, then binds
Good link, thanks for sharing, and your time. God knows you have your hands full
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-14-2015, 01:53 PM   #227
IronCanine
I'm trying....
IronCanine's Avatar
Wow your PO was ridiculous! Glad you're moving forward. Those bottlenecks where progress grinds to a halt drive me crazy. Hope you can get the threads squared up...these trucks are funny...they don't always respond or reciprocate to the love you're giving them.
...and thanks for your kind words...I have been following and referencing your build thread since the first time I clicked on this site. It is a "Pillar" thread for the Blazer/Jimmy build forum.
IronCanine is offline   Reply With Quote
Old 01-14-2015, 02:24 PM   #228
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Also, check your threads on the spindles. One of mine was pretty chewed up but I was lucky enough to save it. I used a small file and with little fitness and patience I was able to clean it up enough for the spindle nut to go back on smoothly.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 01-14-2015, 02:53 PM   #229
jaros44sr
jaros44sr's Avatar
You are being kind to my PO, i ve used worse words than that in my work shop. I thought i was done with him, but his hand keeps popping up....he didn t use a second locking nut, so possibly the tang on the ring has boggered up some of the thread
Thanks for following along w/ my thread, i tend to gear it to the 16 year old who doesn t have a father to guide him, not the long time gearheads on this forum
I think the stock builds are great, keeping original is often difficult. As you can see my build tends to morph
Dark Olive, i have a thread file with a 16 tpi side, hoping that will work, but now i have to disassemble the hub to get at it
SAFETY FIRST
AS usual, off topic
Jim
Old 01-14-2015, 07:44 PM   #230
IronCanine
I'm trying....
IronCanine's Avatar
A few more piercings and associated jewelry. Started on the tailgate trim and one of the strips came out of the box bent....at least one thing could be like, I don't know, easy?
Old 01-15-2015, 09:33 PM   #231
IronCanine
I'm trying....
IronCanine's Avatar
The real difference between a base K5 and a CST: 119 holes.
Console, glove box emblem, rear panel brackets and trim, door badges, belt molding, tailgate trim and molding...
....you spend all this time trying to fix holes just to turn it into Swiss cheese.
Edit: That glove box door was literally the first part I bought for this truck after the truck itself. Got it from member teeitup. Perfectly straight and no holes...until today. It's also got a helluva SPID on it...will be kind of sad to take it off.
Old 01-15-2015, 09:45 PM   #232
IronCanine
I'm trying....
IronCanine's Avatar
....Well sir I see you've selected the top of the line CST package...nice choice, nice choice...Did you know that package means 119 extra holes in your truck...What a deal!...but you know Brad, can I call you Brad?, great, what'll really set you apart from the neighbors...and isn't that what it's really all about right?, exactly...wrap your mind around this....let me cut 3 more holes in your dash and bigger ones in your firewall...I can see it now...you'll be the talk of the town...Less for more they'll say! Why it's as American as apple pie!
Old 01-15-2015, 10:05 PM   #233
DeadheadNM
Carpe manana
DeadheadNM's Avatar
LMAO! Looks great!
Old 01-15-2015, 10:15 PM   #234
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by DeadheadNM View Post
LMAO! Looks great!
Thanks Pete...the only thing better than an unstamped repop tailgate is one dressed with the heretical and dreaded BLACK TAILGATE BAND! ....which now that I type that would be a good name for an actual band.
Old 01-16-2015, 01:52 AM   #235
jaros44sr
jaros44sr's Avatar
ROTFLMAO......your not a used car salesman by any chance? Chervrolet, at one time had OK Used cars
Screenshot_2015-01-16-00-48-03
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2015, 10:14 AM   #236
smbrouss70
smbrouss70's Avatar
I'm not sure if you are going for a totally correct 1970 fully loaded Blazer, or just correct-looking, but those mirrors were not offered until the 71's came out.
I do like that you put the 8-350 emblem under the K/5 emblem. That's where mine is from the factory. I guess that was an early '70 thing, because I have seen other '70 Blazers with the engine size under the marker light.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-16-2015, 10:40 AM   #237
IronCanine
I'm trying....
IronCanine's Avatar
ROTFLMAO......your not a used car salesman by any chance...
No...but my wife thinks this whole thing is a good idea...so....
No...there are a lot of "not" 70 things on this truck that I took a little license on. I just have never liked the 70 and earlier mirrors at all. My brother had a 70 SWB when I was a kid and even then I thought that truck was perfect except for the mirrors. It's also got (or gonna have) a single wall top, disk brakes, tilt, a cup holder console, AM/FM, a black tailgate band, a vintage air set up, silver paint...and I don't think I'm gonna black out the headlight bezels. I drool over perfect "Bloomington Gold" level restorations. But that's not what this is. I love searching and finding and learning what's correct...fussing over it for fun where it makes sense...but I'm comfortable with it just being a well done "period" correct resto....Hey here's a term for ya: "Period-Mod"...I haven't heard that one at Barrett Jackson.
Old 01-16-2015, 10:52 AM   #238
smbrouss70
smbrouss70's Avatar
"Period-Mod" I Love it! I hope you don't mind, but I'm going to start using that one. When you do hear it on B-J you'll be able to say that you coined the term.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-16-2015, 11:47 AM   #239
IronCanine
I'm trying....
IronCanine's Avatar
That's the real reason I had such a hard time constructing my SPID and why Jeff was so helpful. There are things on the truck that you just couldn't get in 1970...but I still wanted a new SPID that reflected what the truck is. Jeff was awesome helping me sort through it. A lot of thought went into that SPID and there's a lot going on in it. I'd be willing to bet some of you RPO aficionados were already way ahead of me.
Old 01-16-2015, 09:47 PM   #240
IronCanine
I'm trying....
IronCanine's Avatar
The hood came off of a 72 truck. The driver's door came off of a 71 truck. Both of those things required sorting.
Old 01-16-2015, 10:04 PM   #241
IronCanine
I'm trying....
IronCanine's Avatar
I wish I could show a beautiful new grill assembly mocked in. But the reproduction unit that I got fit so poorly we are sending it back and trying again. Trust me when I tell you it was well beyond massaging. It's funny too, because the front of the truck is all really nice unmolested OEM stuff.
Old 01-16-2015, 10:09 PM   #242
IronCanine
I'm trying....
IronCanine's Avatar
All holes drilled...It's finally time to start body work!
Old 01-17-2015, 12:35 AM   #243
smbrouss70
smbrouss70's Avatar
Not sure if you have the coin for it or not, but there is a NOS grille on ebay right now.
http://www.ebay.com/itm/NOS-69-70-CH...d30879&vxp=mtr
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-17-2015, 12:38 AM   #244
Blown06
Blown06's Avatar
I'm loving what you're doing, taking all the cool stuff from the different years and putting them to use. Really sucks about the grille shell though, doesn't give me a warm and fuzzy knowing I'm gonna need one for my 71.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 01-17-2015, 10:48 AM   #245
IronCanine
I'm trying....
IronCanine's Avatar
That's an awesome piece...I'll keep my eye on it. I'm going to give these guys a chance to get me one a little better first. Really I am trying to stay within a long distance phone call of the original budget.
Thanks. It's a straight up 70, that was my preference when I started the search and was glad to find it...such that it was. And we've tried to stay true to it. It already had the single wall top and the front axle swap so that was a no brainer...the only real non factory "choices" I've made are mirrors, steering wheel, console, paint, and TG band...and radio....and A/C...well I guess when you list them out like that it is a lot...um...yeah...thanks. That's what I was going for the best of all years
Old 01-17-2015, 03:51 PM   #246
Chulisohombre
Chulisohombre's Avatar
Nice build. Stole a few pics for later reference. You don't get to see a lot of Blazers completely bedsides removed and all the frame work you did. I'll be watching.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-17-2015, 04:13 PM   #247
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. Wish we hadn't had to do that level of rust repair...wasn't the kind of fight I was looking for. But we played the hand we were dealt at that point. Luckily we're starting to get into the short rows.
Old 01-17-2015, 04:27 PM   #248
Chulisohombre
Yeah. I half ass rebuilt mine to the piont it just looks ok. It would take a ton of coin to get it in the condition yours will be in. Money is always tight so didn't have the time or fundage to go the rought you did. Someday maybe but won't be til my kids are out of the house probably. It's looking real good though.
Old 01-20-2015, 08:42 PM   #249
IronCanine
I'm trying....
IronCanine's Avatar
Dust on the floor can be a beautiful thing...when it means body work has started.
Old 01-20-2015, 11:10 PM   #250
Chulisohombre
Just cover everything up. That dust gets everywhere. Lol
1970, blazer, k5 blazer, restoration, silver
