Old 03-03-2017, 10:44 PM   #1
Houston Ben
Houston Ben's Avatar
Drop spindle differences by brand?
Hi all,
86' C10 stock 15X8 rally, Looking at 2.5" drop spindles (1" rotor) but most searches come up with 67-72 trucks. I have seen posts that say drop spindles push out the wheel a little, is this just on 67-72 or all? If this is the case, what brand will move them the least? I emailed CPP but they told me they don't manufacture spindles for the 1" rotor.
I found Western Chassis spindles for 1" rotors on Summit, but at the moment the price is $603, no thanks! I have an email in to see if this is a typo.
Any other suggestion I should look at that won't affect the track width?
Thanks for any input.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 03-04-2017, 12:03 AM   #2
bbbc10
Diggin The SquareLife
Re: Drop spindle differences by brand?
cpp does not make spindles for 1" rotors only 1.25.
western chassis spindles are not $600 from summit I think I paid around $260 when I bought mine.
all spindles will push the wheels out.
also western chassis spindles will not cause the wheel to rub on the lower control arm....all other spindles will cause the wheel to rub on the lower control arm an you will have to grind on the control arm for it not too.
bbbc10 is offline   Reply With Quote
Old 03-04-2017, 02:45 AM   #3
UKNOWME
UKNOWME's Avatar
Wow that must be a typo but I also see the 600 dollar price tag as well as the shipping date of next month. Someone else on the forum was talking about them being backordered. Might try calling western chassis and buying direct for 260.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 03-04-2017, 07:22 AM   #4
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Drop spindle differences by brand?
This is true but it depends on what wheels(size and backspacing) you have.
We need an ask all tell all sticky'd drop spindle thread on here
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 03-04-2017, 08:11 AM   #5
bbbc10
well I know it depends on what size and backspacing is...smh I was just letting him know that he will not have that problem with STOCK 15X8 RALLYS WHICH HE CLEARLY SAID HE HAS. thanks
Old 03-04-2017, 09:45 AM   #6
RDrancher
RDrancher's Avatar
Summit has the WC spindles for $235.97 with free shipping, but they're on backorder.
Keep in mind that Summit now charges tax on Texas, so be sure to figure that into your shopping equation.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 03-04-2017, 10:32 AM   #7
Houston Ben
Thanks for replying all. I should have stated I have stock upper and CPP lower control arms. I just looked again and the WC spindles I need still say $603 lol. How are the McGaughy's?
Old 03-04-2017, 10:34 AM   #8
KrazyRay
KrazyRay's Avatar
I used DJM 3" drop spindles on my 87 with the 1" rotors and I did not have to grind the control arms. I'm running 15x8 Rally wheels.
KrazyRay is offline   Reply With Quote
Old 03-04-2017, 11:03 AM   #9
UKNOWME
UKNOWME's Avatar
I have McGaughys on 2 of my trucks and haven't had any issues.
1964 Chevy c10
Old 03-04-2017, 11:44 AM   #10
Rockbottom78
Rockbottom78's Avatar
I also used DJM, but on 1.25" rotor. One oem 15" rally wheel is good the other rubbed slightly on the caliper. Good price on summit for sure. I have to say the DJM 3" is more like a 2.5" drop realisticly. The only other thing I had to do for install was bend the hard lined part of the brake line where it mounts the to spindle. Gunna have to cut some of my inner fender to tuck without rubbing now too.
Rockbottom78 is offline   Reply With Quote
Old 03-04-2017, 02:41 PM   #11
Malo83
Cruzzzn' Vet
Malo83's Avatar
Brothers has Western spindles for $269.99 in their catalog.
Malo83 is offline   Reply With Quote
Old 03-04-2017, 03:30 PM   #12
Houston Ben
Thanks again all,
Since my brakes are starting to bounce, I was thinking of just upgrading to the 1 1/4" brakes. I can get WC brake kit and spindles for $578, seems like a good price.
It is weird, the brakes are not shimmying like they are warped, just bouncing when I press hard when I have to slow down fast.
Old 03-04-2017, 05:05 PM   #13
Nick_R_23
Nick_R_23's Avatar
Arrow Re: Drop spindle differences by brand?
Please stop spreading this false information. Multiple 2.5" drop spindles will work just fine without causing the wheel to rub the control arm. This was just discussed in the recent thread.
Old 03-04-2017, 06:55 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
The rub come from the amount of backspacing you have on a 15" wheel.
To compare apples to apples you have to have the wheel info when you are talking spindles and the wheel rubbing the lower a-arm.
All of this has been discussed to death on this forum.
Keith
Convert to disc brakes.
Old 03-05-2017, 12:59 AM   #15
bbbc10
Not false so you might want to get your info right. Thanks☺
Old 03-05-2017, 01:24 AM   #16
Nick_R_23
Nick_R_23's Avatar
Exactly. Although in this case, the OP specified a stock 15x8 rally wheel, which should clear just fine.
It is. As it has been pointed out by several posters in multiple threads recently, other 2.5" spindles will clear a 15x8 rally wheel just fine. I can personally verify this with the 15x8 rally wheels on my truck and spindles that are not Western Chassis and do not rub my control arm.
