Old 01-27-2018, 08:27 PM   #1
novafrog
novafrog's Avatar
fuel pump and tank
this is a fellcellguys tank(I think that is his name)tank is for carb.now going to fi ,tank is 8 1/2 ins. deep, what is the best intank pump and ring to use(2000 5.3) would it matter where i put it,i was thinking middle,i have ask a few question and you guys have help a lot,this is my first swap,i will more than likely have some more,thanks very much
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 01-28-2018, 01:19 PM   #2
DLW
Re: fuel pump and tank
I like the Aeromotive Phantom Stealth Systems.
https://www.summitracing.com/parts/aei-18688
DLW is offline   Reply With Quote
Old 01-28-2018, 03:18 PM   #3
Aberdare
Aberdare's Avatar
Why modify your tank? Just use an inline high pressure fuel pump mounted inside the frame rail with an inline fuel filter... then you're all set with minimal fuss.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 01-28-2018, 03:21 PM   #4
novafrog
novafrog's Avatar
that's a lot of money,was looking for something like that in a gm style,i saw one on here where a guy got the ring and welded to the tank put there pump in bolted to ring but I can't find it now
03 cat.
06 gmc swb ext cab
Old 01-28-2018, 03:31 PM   #5
novafrog
novafrog's Avatar
I got one walbro 225 I think when I first started this swap,had to drop tank to put in return line, thought now would be good time for in tank pump.i don't no this is my first swap,trying to do the best first time around and hopefully not have to worry about it
03 cat.
06 gmc swb ext cab
Old 01-28-2018, 05:06 PM   #6
mongocanfly
mongocanfly's Avatar
nothing wrong with a intank or inline pump...both do the same job...if you've already got a walbro and vett filter/reg I'd just go with that..I've been running one in mine for years with no issues....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-28-2018, 05:10 PM   #7
mongocanfly
this may be similar to what your looking for.....
http://www.gearhead-efi.com/gm-ecm-p...onversion.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-28-2018, 07:43 PM   #8
novafrog
novafrog's Avatar
I think i'll just go inline ,want to thank all you guys for info
03 cat.
06 gmc swb ext cab
Old 01-28-2018, 07:45 PM   #9
novafrog
novafrog's Avatar
that's what I had in mine,again thanks
03 cat.
06 gmc swb ext cab
Old 01-28-2018, 09:30 PM   #10
DLW
Well, in your post you said best, not cheap, so that is why I went there
I would do an in tank pump any day over an inline pump if I had an option.
Old 01-28-2018, 09:38 PM   #11
novafrog
novafrog's Avatar
ol well
03 cat.
06 gmc swb ext cab
Old 01-29-2018, 07:05 AM   #12
NC_John
NC_John's Avatar
I was thinking the exact same thing.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-29-2018, 11:15 AM   #13
novafrog
novafrog's Avatar
maybe I should have said GOOD WAY
03 cat.
06 gmc swb ext cab
Old 01-29-2018, 11:25 AM   #14
ls1nova71
ls1nova71's Avatar
I would go in tank too, from a reliability stand point, and the fact that your tank isn't baffeled at all. When the tank gets low, that electric fuel pump pushing the fuel to the engine at 58 psi, is going to starve for fuel during acceleration and cornering. On a carb'd engine you don't notice it because the fuel bowls hold enough fuel for the pump to catch up, but on an EFI engine, the stumble will be instantaneous. With a tank like you have, I would use a factory sender/fuel bucket type pump, that way you always have fuel at the pump. You can either buy something like a Vettworks adapter or make one since they're not very complex, then get a pump from a truck that matches the depth of your tank, Tahoe's are shorter than Silverados. http://www.vetteworksonline.net/cata...qln9hmmunf50v5
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-29-2018, 11:40 AM   #15
novafrog
novafrog's Avatar
that's what I wanted to do, that nova that u see in my pic. has in line and its as loud as car,thanks
03 cat.
06 gmc swb ext cab
Old 01-29-2018, 11:49 AM   #16
ls1nova71
ls1nova71's Avatar
This is the last one I did, it's on a 59 Chevy, but same idea. You probably wouldn't need to recess the tank on a truck like I had to do. https://ls1tech.com/forums/conversio...r-wagon-5.html Tank mods start at about post 94.
Old 01-29-2018, 12:29 PM   #17
raic65
raic65's Avatar
I use this in my truck. It uses a 5th gen camaro fuel pump module.
https://www.vaporworx.com/
https://www.vaporworx.com/product-ca...ounting-rings/
and I'm assuming your tank is not baffled, use these too.
https://www.vaporworx.com/product/cptkit/
raic65 is offline   Reply With Quote
Old 01-29-2018, 05:41 PM   #18
novafrog
novafrog's Avatar
i talk to dan at vettworks and he's going to try to find me a aluminum ring,his was ss my tank is aluminum if he can't i'll make on , thanks ls1 and raic65
03 cat.
06 gmc swb ext cab
Old 01-30-2018, 12:56 PM   #19
raic65
raic65's Avatar
No problem Novafrog. Just so you know Vaporworx has an aluminum ring you can weld to your tank. A little pricer, but the pump setup you will use no longer needs an external regulator. You'll only run a feed line to the engine. The regulator is housed in the fuel pump module.
Old 01-30-2018, 01:52 PM   #20
novafrog
novafrog's Avatar
just talked to carl, his set up seems to a lot simpler, how would you block off return line, thanks for info
03 cat.
06 gmc swb ext cab
Old 01-30-2018, 02:29 PM   #21
mongocanfly
you can get fuel grade rubber caps....or just use it as a extra tank vent..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-30-2018, 08:09 PM   #22
ls1nova71
ls1nova71's Avatar
You're using a 5th gen Camaro pump, right? Because the earlier modules all have returns on them.
I personally do not care for the whole blocking off the return line thing, to me its a car fire waiting to happen. I would get a pump with a return and run it like factory since your engine is set up for a return. High pressure fuel systems really aren't the place to cut corners to make things appear easier....
Old 01-30-2018, 08:14 PM   #23
ls1nova71
ls1nova71's Avatar
This is another reason I dont like blocking the return line. I'm pretty sure he's talking about the line on the rail, and a little miscommunication going on here. If someone tried to use these on the rail, it would only be a matter of when, not if there will be a fire.
Old 01-30-2018, 09:23 PM   #24
novafrog
novafrog's Avatar
yes both guys have 5th gen pump, both said by my tank being just 8 1/2 in tall that 5th gen pumps was all I could use,4th gen was to long even if cut ,shortest it could be is 10in,if I did't have 500.00+ in my tank I would buy a tank, don't have money for that everything else fells,inline pump
03 cat.
06 gmc swb ext cab
Old 01-30-2018, 09:24 PM   #25
novafrog
novafrog's Avatar
yes talking about line on rail
03 cat.
06 gmc swb ext cab
