Old 08-12-2019, 03:10 PM   #1
dieseltech
Dodge Dana 60 spring perch heights
Hey I did a bit of searching but came up empty. I’m putting a 93 D60 in the front of my 86 K10 and noticed that when I mounted the axle and it appears the spring perch is taller on the drivers side than on the passenger side. Any one ever run into this?
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
Old 08-12-2019, 05:54 PM   #2
sweetk30
sweetk30's Avatar
Re: Dodge Dana 60 spring perch heights
only real problem is fixed with this kit here that i know of . http://offroaddesign.com/catalog/Dod...apBushings.htm
and just a fyi you get almost 1" of lift on a dana 60 swap cause its so much bigger .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-13-2019, 08:18 AM   #3
dieseltech
Yes I got that issue sorted as I’m using all aftermarket spring hangers. The issue is that the drivers side spring perch is physically taller than the passenger side perch. Not sure if there is a small lift block that’s supposed to be there or not.
305/700r4
6" lift
37x14.50x15
Old 08-13-2019, 03:41 PM   #4
sweetk30
sweetk30's Avatar
i worked on 1 truck my self with a dodge under a gm and did not notice a problem .
have you realy looked it over with a tape measure from pad to tube ? the gm 60 uses a taller perch on driver side than 1/2 and 3/4 ton fronts do . so it might be a optical illusion .
otherwise set her up and measure the truck and if need be add in a old leaf spring cut down to just a spacer length and add it in the bottom of the pack to level it out via sandwiching it with the center pin like a leaf .
