01-09-2024, 06:17 PM | #26 |
Re: Chev-odge: ‘71 K20 Cummins build
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
01-10-2024, 01:16 AM | #27 | |
01-10-2024, 12:00 PM | #28 |
Good time to do it it though...
01-11-2024, 01:23 AM | #29 |
01-11-2024, 10:50 AM | #30 |
Then rock-on Amigo!
01-17-2024, 04:01 PM | #31 |
At the machine shop, it’s cleaned up and passed magnaflux testing
01-17-2024, 04:03 PM | #32 |
Bored .020 over
01-17-2024, 04:48 PM | #33 |
Machined the block and head
01-17-2024, 04:56 PM | #34 |
That’s a wrap at the machine shop…
01-17-2024, 04:58 PM | #35 |
Back at Jim’s place…block, head and crank are all set. New cam too!
01-25-2024, 11:06 PM | #36 |
Back on the stand!
01-25-2024, 11:08 PM | #37 |
New rods and pistons, .020 over.
01-25-2024, 11:11 PM | #38 |
Progress!
01-25-2024, 11:12 PM | #39 |
In the pump
01-25-2024, 11:14 PM | #40 |
Oh yeah!
01-25-2024, 11:16 PM | #41 |
Lined up and KDP secured
01-25-2024, 11:17 PM | #42 |
Ready, Set…
01-26-2024, 11:11 AM | #43 |
Active Member
Awesome progress
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
01-27-2024, 12:34 PM | #44 |
01-31-2024, 12:53 AM | #45 |
great project! curious about new rods vs getting the old ones rebuilt?
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
02-04-2024, 02:31 PM | #46 |
Cool build!
Good choice to go through the Cummins now I have a Chevy-Dodge too. Built it in 2003 using a rolled over 02 Dodge. I used the entire drivetrain and chassis on mine- been using it for over 20 years.
71 C10 72 K20 72 K10 Super Kirk |
02-12-2024, 01:01 AM | #47 |
02-12-2024, 01:04 AM | #48 |
Thank you, I’ve always wanted one…how difficult was it to put the Chevy on the Dodge chassis?
02-12-2024, 01:08 AM | #49 |
Back at it…I wanted to locate the position of the 350’s harmonic balancer vs the frame, which then I can use in locating the Cummins.
02-12-2024, 01:12 AM | #50 |
I also made a note of where GM locates the engine cross member and will measure the distance from the center of the mounts to the front of the balancer, and compare that to the Cummins mount location…I’ll attempt to use the Mopar crossmember and new mounts on the project.
