Old 01-14-2010, 09:23 PM   #26
50adrod
50adrod's Avatar
Re: Project 54 short
Originally Posted by eventytoo View Post
air ride 3 link ..... joke went to a trianglated 4....mar-k bed shortened...17 gal tci fuel cell between the rails marine fuel cap...
where did you get the 3 link? how wide is that 95 rear axle? thanks
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 01-15-2010, 01:40 PM   #27
eventytoo
Used the art kit for an s10 the upper link did not work for me. The quality was good but didnt work in my applacation. I kept the lower rods mounting points ect. But the upper rods I went with half of an tri 4-link setup. I also boxed the frame and moved the rearend back 3 inches. I dont recall how wide the rearend is 60 inches? I know it was within an inch of the stock one. The coresupport is made out of steel tubing.
eventytoo is offline   Reply With Quote
Old 02-07-2010, 09:08 AM   #28
eventytoo
I got the running boards shortened. I took 3 inches out of them. Also shortened the filler plates. I used fusor t21 and bonded the fiberglass running boards back togerther. Primed with omni mp170 epoxy then k36 surfacer Thought id share some pictures.
Old 02-07-2010, 10:32 AM   #29
Dan Bowles
AD Addict
Originally Posted by BlueJeep View Post
Can you post pictures of how you did the radiator support?
I've got the same question here! I pushed my rad WAY out at the bottom to clear when I used the stock one. I trimmed back the bottom air dam from the grill. I'm starting another AD/S10 now and am looking for options.
Looks good on a short box frame, by the way.
Dan Bowles is offline   Reply With Quote
Old 02-07-2010, 07:21 PM   #30
eventytoo
Lots of block sanding on the rear fenders ichy fiberglass. I sprayed the inside of both of them with HERCULINER to help wth flying rocks.
Old 02-07-2010, 07:31 PM   #31
eventytoo
Picture of the seat a start atleast. I cut one spring in half was not thinking might have to visit the u pull yard of mabe somone knows where you can get replacement springs for a 72 chevy truck seat. I mounted it in the cab and the ajustment handle is out the door so that will have to be changed or i may go with a power ajust time will tell so much other things to do.
Old 02-07-2010, 07:40 PM   #32
eventytoo
New or should I say new used Hood. Has been primed with epoxy and surfacer but no pics.
Old 02-07-2010, 07:43 PM   #33
eventytoo
I would like to help you on the core support but the hood is mounted and has no springs on it to hold it up so if you could imagine not to posable to take a pic of that right now.
Old 02-07-2010, 08:10 PM   #34
eventytoo
Pictures of some body off restos iv done. 72 chevy custom 20 350/350 390 hp wood bed bucket seats ac. 76 GMC 35s 4inch lift 350/350 Pro-flo fuel inj. I started the 72 when I was in Highschool. Took two years The summer I graduated I completed it. The 76 took 9 months talk about long days college work and then the project. It was worh it.
Old 02-07-2010, 11:29 PM   #35
MrTucker
MrTucker's Avatar
Nice trucks! You sir, have a lot of talent.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 02-07-2010, 11:56 PM   #36
matthew.doan
are the fiberglass fenders better to use?
matthew.doan is offline   Reply With Quote
Old 02-08-2010, 11:44 AM   #37
texas56
texas56's Avatar
Awesome!
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 02-17-2010, 11:53 AM   #38
eventytoo
A few pcs. painted a lot to go...
Old 02-17-2010, 12:10 PM   #39
kustombrad
kustombrad's Avatar
Right on! Looking good!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 02-17-2010, 12:14 PM   #40
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-17-2010, 12:49 PM   #41
MrTucker
MrTucker's Avatar
How about some more pics of your truck from the side? I'd love to see more of how it looks on a short bed s10 chassis with a shortened bed. I'm asking cause there seem to be about 10 shortbed s10's in my area for sale for practically nothing and only a few long bed reg cabs...
Old 02-17-2010, 01:02 PM   #42
Daniel U
Daniel U's Avatar
Me likey!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 02-17-2010, 03:50 PM   #43
eventytoo
I moved the rear axle back. Its no longer a true short s-10. The running board filler plates sectioned 2.75 inches. And I took 3.0 inches out of the running board.
Old 02-17-2010, 03:56 PM   #44
MrTucker
MrTucker's Avatar
Gotcha...how far back did you move the rearend?
Old 02-17-2010, 03:57 PM   #45
eventytoo
Originally Posted by Daniel U View Post
Me likey!
Thanks and thank you everyone else the commented.
Its not a the same green as yours Daniel, Or atleast I think. 1996 GM color. I think they changed it in 02..
Old 02-17-2010, 04:19 PM   #46
eventytoo
The front oe spring mount plates im using moved those back 3 inches. The rest of the suspension is not stock. All air ride. The rear fenders I moved back 4.75 inches from the stock pre drilled holes. Why the difference in numbers I have not a clue. I used a 3/4 ton box and shortened the front.
With all do respect. Get the correct frame. Or better yet use the stock one do the math on this Mr. Trucker. Pannel fitment is a beast with the s-10 frame. Narrow frontend. You have to make mounts to mount cab ect. Then the rearend still is not correct to narrow. Price a mustang 2 setup. Then price all new front end componnts for the s-10. Darn near the same arnt they. I know in going to get proved wrong on this one I dont mean to start anyting also Thanks.
Old 02-17-2010, 06:26 PM   #47
MrTucker
MrTucker's Avatar
I hear ya - it just looked like you just chopped a couple extra inches off the bed and it all fit, that's why I finally had to ask.
I'm probably going to do an S10 swap because my frame is tweaked and I dont trust it. And rather than spend a ton of money getting a new AD frame, an MII front end, and a new rear suspension - an S10 makes too much sense. And since I'm starting with a long bed '53 I'm going to have to cut my bed down anyways.
Thanks for the info...
Old 02-17-2010, 07:12 PM   #48
texas56
texas56's Avatar
I agree, the sheetmetal fitment is the hardest part of the whole swap. Especially if going to paint it. If just gonna ruff it in, it wouldnt be too bad.
Old 02-20-2010, 08:18 AM   #49
eventytoo
I wanted two inch wider rear fenders. They are only made in fiberglass. It depends what you mean by better to use.?.
Old 02-20-2010, 05:31 PM   #50
Dan Bowles
AD Addict
I've got a local guy that swears by the glass fenders. He drives his truck year round here in MI so it's a must. Salt sux.
