Old 07-20-2007, 12:01 AM   #176
56chevy1300
56chevy1300's Avatar
Re: My Project 56Chevy1300
I found a u-joint/vibration dampener from Borgeson. I'm going to look into it further.
56chevy1300 is offline   Reply With Quote
Old 07-20-2007, 12:04 AM   #177
56chevy1300
Had some time yesterday to install my power brake booster/mc
Old 07-20-2007, 11:55 AM   #178
Daniel U
Daniel U's Avatar
Will you need another access hole in your floor board? This will keep your firewall clear.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 07-20-2007, 12:03 PM   #179
watahyahknow
watahyahknow's Avatar
would be a great solution with a whole lot of newer cars too when they want to shoehorn a bigblock in it .
one of the things that engine will hit is the booster itself
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-20-2007, 12:39 PM   #180
56chevy1300
Yah, looks like I will. I didn't look in the cab but I think its going to end up being cut right under the seat.
Old 07-22-2007, 04:31 PM   #181
56chevy1300
Finally got the entire front end completed, first time testing the bags, everything works great, might need to regrease the lower control arm bushings.
10" of travel! 5" from bottom of front frame horn when bags empty and 15" when bags have 60 psi in them.
Old 07-22-2007, 04:33 PM   #182
56chevy1300
Crossmember: 1.5" from ground when empty / 8.5" when full.
Old 07-22-2007, 04:39 PM   #183
56chevy1300
few more pics
Old 07-22-2007, 06:40 PM   #184
CAL 58 GMC
CAL 58 GMC's Avatar
Now that's a lot of travel!
CAL 58 GMC is offline   Reply With Quote
Old 07-22-2007, 10:07 PM   #185
56chevy1300
I hear yah bud!...Im surprised at the amount of lift myself
Old 07-22-2007, 10:12 PM   #186
56chevy1300
Was a productive day...started working on the rear axle and removing the rear leaf springs.
Does anyone know how to remove these shackle bolts?
Old 07-23-2007, 12:21 AM   #187
dwcsr
Hollister Road Co.
dwcsr's Avatar
The rear shackle bolts are threaded into the perch. You remove the nuts on each side then remove the shackles on each side and screw out the bolt..
The front one there is a wedge pin that holds the spring pin in place. it has a nut on one side... Remove the nut and drive the pin backward to remove it. then from the inside of the frame drive the spring pin outward.
I would soak them for a few days with kroil or some other penetrating oil.
save the shackle parts they get $20 a pair on ebay.
dwcsr is offline   Reply With Quote
Old 07-25-2007, 04:35 PM   #188
56chevy1300
Thanks for the info dwcsr...after some deliberation I decided to go with a four link air kit from TCI instead of dealing with a set of 50 year old springs.
Also dropped the rear jackstands and positioned a rear wheel to get a look at the new stance.
Old 07-25-2007, 07:35 PM   #189
56chevy1300
Bought some guages today: Classic Instruments Silver series.
Old 07-26-2007, 10:01 PM   #190
56chevy1300
Forgot to install the sway bar; this thing is a monster! Had to drill out the bushing because CPP sent me the wrong size twice.
Old 07-27-2007, 01:30 AM   #191
56chevy1300
My father and law gave me his 93 Aerostar van. I drove it for several weeks before it bit the dust. I got rid of the van but before I did I pulled the 2nd row leather buckets out. I am thinking of dyeing them charcoal gray to match my interior and install them into my 56. They are in good condition. The passenger side seat has 2 armrests and the driver has 1 one the right hand side. I will have to fab my own brackets for them.
Old 08-24-2007, 10:02 PM   #192
northerngmc
northerngmc's Avatar
Welcome back from vacation.......
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 08-25-2007, 03:03 AM   #193
lotussutol
I like these a lot. where did you buy them at?
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 08-27-2007, 04:28 PM   #194
56chevy1300
Go to www.classicinstruments.com.
Old 08-30-2007, 06:36 PM   #195
northerngmc
How about these seats?
Blaine
Old 09-02-2007, 11:27 AM   #196
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet build thread.... Keep up the good work...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-02-2007, 08:48 PM   #197
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
i love the new stance
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 09-03-2007, 11:40 PM   #198
56chevy1300
Hi Blaine,
Thanks for the pics, I'll send you a PM.
Old 09-03-2007, 11:47 PM   #199
56chevy1300
Thanks, I think it'll look good when its done...should be a rolling chassis soon as the 4 link is done.
Old 09-04-2007, 12:14 AM   #200
lotussutol
I wish I could do the under the cab brake booster. I had to cut out some of that bracket though to get my tranny crossmember in. It wanted to end up right under the brake bracket.
I am going with a firewall mounted unit. I have the pedal assmbly and booster/master from an s10 that I am going to use I think.
Lotus
