Old 11-30-2006, 03:18 PM   #1
stevehsd
stevehsd's Avatar
My '51 Project
Hi,
I'm new here to Post but have been reading a lot!
Great info! Quality work! Tons of ideas!
So I decided to start my work up. Here's what I have to start with.
And a pic of my last project that I abandoned in favor of the truck
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 11-30-2006, 03:29 PM   #2
texascowboy593
texascowboy593's Avatar
Re: My '51 Project
Good solid truck to start with. What are some of your plans? Any modifications coming? Welcome to the board and keep us posted!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 11-30-2006, 03:33 PM   #3
Zumo
Hot Rods For Life
Zumo's Avatar
Re: My '51 Project
Where did you abandon it? I'll go pick it up.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 11-30-2006, 03:59 PM   #4
stevehsd
stevehsd's Avatar
Re: My '51 Project
Sold the 29 model A for what I paid for the truck!
My plans are Must II IFS , 350, 700R, Triangulated 4 bar rear, all bagged.
I want the truck to sit on the floorboards with the air out.
Tell me how? C notch the rear? 2 in dropped spindles ? I need to know!
Here are some pics that did not fit the first time.
77 FLH
Old 11-30-2006, 04:10 PM   #5
stevehsd
stevehsd's Avatar
Re: My '51 Project
Here's what I've done.
Replaced side glass
Did headliner
pounded out rear fender
Got old plates registered!
Got an old cooler for the bed
Took off frount end
Am preppeing for the Must II
77 FLH
Old 11-30-2006, 04:12 PM   #6
stevehsd
stevehsd's Avatar
Re: My '51 Project
77 FLH
Old 11-30-2006, 04:13 PM   #7
stevehsd
stevehsd's Avatar
Re: My '51 Project
77 FLH
Old 11-30-2006, 04:23 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: My '51 Project
Nice project man
Kabwe is offline   Reply With Quote
Old 11-30-2006, 04:30 PM   #9
texascowboy593
Re: My '51 Project
The cooler is a nice touch!
1977 Silverado K10
Old 12-02-2006, 01:37 AM   #10
stevehsd
stevehsd's Avatar
Re: My '51 Project
the cooler is as rough as the truck
77 FLH
Old 12-02-2006, 04:01 AM   #11
Daniel U
Daniel U's Avatar
Re: My '51 Project
I like the plate an vintage frame! Are you going to "rat rod" it or go for the finished look? Sounds like between the suspension and frame work you have a good size budget! It all adss up quick. I'm up to $25k without paint, interior or sound!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 12-02-2006, 01:11 PM   #12
Jebb1978
Jebb1978's Avatar
Re: My '51 Project
Looks like a solid start! I think you will need more than a C-notch to lay frame.
May need to Z it in the rear to get it that far down. Welcome aboard!!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 12-02-2006, 07:01 PM   #13
stevehsd
stevehsd's Avatar
Re: My '51 Project
I plan to leave it alone paint wise
It's all the same color so I'm fine with it.
I like the look of the rat rods
I may paint an old shop logo on the door if I can make it look old
How many inches do I need to Z the frame to get it that low?
77 FLH
Old 12-02-2006, 08:06 PM   #14
watahyahknow
watahyahknow's Avatar
Re: My '51 Project
please man instead of going to hack the frame up make a new one and keep the original in storage for another resto job , it will probably too weak for the job anyway
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-03-2006, 10:56 PM   #15
stevehsd
stevehsd's Avatar
Thumbs up Re: My '51 Project
Took off the bed today.
PO had welded the fender to the running board on the right side
Had to grind that off.
All bolts rusted, broke em all
Plan on removing all of the old suspension and rear end
What's that bar behind the crossmember?
Have a Camero 10 bolt rear end I'm planning to use
lots of grinding to do
Hack it up?
too weak?
you think so?
These frames are being given away on the HAMB
I may bolt on a front end
have to see how low the rear will be before I z it
If I take the cab off I may go with another frame
know of one with must II welded in already for 100
I am learning as I go
I just feel like I'm tearing it apart but that has to happen to improve the stance.
Thanks for your input!
Old 12-03-2006, 11:04 PM   #16
pgf545
pgf545's Avatar
Re: My '51 Project
Steve, Are you talking about the solid metal bar with a hump in it? If so that is your emergency brake. I pulled out the one in my dads truck because we went with a different rear end and it uses cable type e-brakes. If that is not what you are talking about then post a picture and I will see if I can help you out.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 12-06-2006, 10:17 PM   #17
stevehsd
stevehsd's Avatar
Re: My '51 Project
Here's what the front looks like with no springs, just sittin' frame on axle.
Will a must II get it this low? lower?? I like it!!!
Old 12-06-2006, 10:25 PM   #18
stevehsd
stevehsd's Avatar
Re: My '51 Project
PGF no not the brake one, there's one behind the rear cross member.
Bolted on. Also the rear cross member , tire hanger, is bolted at the top with what looks like adjustable slots? I'll try to post pics.
Old 12-07-2006, 09:34 AM   #19
Sweet&LowPro55
Sweet&LowPro55's Avatar
Re: My '51 Project
Solid truck to start with.Looks like your making good progress.Hey... I like the rod also ,Nice !!
http://i142.photobucket.com/albums/r...MyExtremeD.jpg
~ '55 Chevy Pro-Street P.U. Powered by 396c.i. ~
~ '01 ChevyS10 Extreme LS Ext. cab
~ '92 Camaro RS 25TH.Limited Edition Aniv.Convert.
~ '98 Dodge Ram Van 5.7 Litre
~ '98 E-Z-GO Golf Car ..Tony Stewart Edition
!! '69 Camaro SS..SOLD .. Still crying !!
Sweet&LowPro55 is offline   Reply With Quote
Old 12-07-2006, 12:17 PM   #20
Daniel U
Daniel U's Avatar
Re: My '51 Project
My TCI Mustang II front end came in this last week. I'll see if I can get some pics up with it installed soon. Be watching for it in my build thread.
Old 12-07-2006, 12:48 PM   #21
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: My '51 Project
It should be close to that with drop spindles
Old 12-13-2006, 10:06 PM   #22
stevehsd
stevehsd's Avatar
Re: My '51 Project
Got the rear springs off last weekend to see what it looks like.
About 4" off the ground front and rear, looks cool.
Researching Mustang II and Triangulated 4 link
Zigs has a special for $3000 front and rear with bags plus brake booster
Suisidedoors.com has some good stuff too
77 FLH
Old 12-14-2006, 09:58 AM   #23
Sweet&LowPro55
Re: My '51 Project
The easy work is almost done ! Then on to the fun stuff.Keep us posted on the progress...................
Old 12-15-2006, 01:29 AM   #24
CAL 58 GMC
CAL 58 GMC's Avatar
Re: My '51 Project
Welcome to the board from central Califorina! Looks like a nice truck to strart your project with!
CAL 58 GMC is offline   Reply With Quote
Old 12-25-2006, 04:32 AM   #25
stevehsd
stevehsd's Avatar
Re: My '51 Project
here's the bed back on
I had to enlist all of the nephews on Christmas eve to put it right!
I just got the wheels, I'm gonna use some '70 Z28 Rallys.
got to hope for some cash from santa to get any farther!
77 FLH
