Old 12-01-2006, 02:11 AM   #1
71/454
Turbo Guy
71/454's Avatar
Cutting keys
Just wading into this new panel truck project and realised I don't have door or ignition keys. Can a locksmith make keys for these. Scottssupertrucks will sell you a blank key, anybody know if a locksmith can fit one?
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 12-01-2006, 11:33 AM   #2
project1971
project1971's Avatar
Re: Cutting keys
A good lock smith should be able to do it no problem. I had seen my Grandpa do it many times, he would go out with some sort of pick and run it in and out of the tumbler and feel what they were and go back inside and cut a key from the feel of the tumbler. So yes they should be able to do it but alot of lock smiths now days only know how to run a machine to make a duplicate key. It is a lost art.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 12-01-2006, 01:17 PM   #3
Daniel U
Daniel U's Avatar
Re: Cutting keys
You might price out how much a new key/lock set runs over having a locksmith cut a new key. I know I'm going with all new ones just for peace of mind. I want a new truck feel when I'm done.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 12-01-2006, 03:22 PM   #4
71/454
Turbo Guy
71/454's Avatar
Re: Cutting keys
Will the door key be the same as the ignition in these trucks?
12 bolt diff
Old 12-01-2006, 05:14 PM   #5
Daniel U
Daniel U's Avatar
Re: Cutting keys
Not sure what truck your speaking of. My '54 had the ignition, glove box and the driver's side door keyed the same from the factory. I currently have a late 60's-early70's style steering column in it, so I'll have at least 2 keys to carry.
Old 12-01-2006, 08:54 PM   #6
71/454
Turbo Guy
71/454's Avatar
Re: Cutting keys
It's a 50 panel. If it was all one key it would be worth cutting, about 25 bucks. Otherwise may as well just put new ones in, only about 20 bucks more than cutting.
12 bolt diff
