Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-16-2008, 08:55 AM   #1
Super73
Super73's Avatar
Auto Gear Calculator
Not sure if anyone here will use this. But I stumbled a site that showed all the different gear ratios for the several transmisions. I threw it in an excel sheet and wrote some equations. Basically if you put in your Gear, Tire, Converter loss and RPM it will give you mph for both a locked and unlocked converter. Might be helpful to figure out what you need.
http://73-ls1.com/misc/gearing_revision_2.xls
If you have a tranny you would like me to add, post the gear specs and I'll add it.
Added RPM vs MPH in 100 rpm increments. Put your info in the first page labeled "Top Speed"
Super73 is offline   Reply With Quote
Old 01-16-2008, 08:56 AM   #2
Outlaw72
Hay Team!!
Outlaw72's Avatar
Re: Auto Gear Calculator
Sweet!
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 01-16-2008, 09:15 AM   #3
Super73
Super73's Avatar
Did you give it a try? Did it work?
Old 01-16-2008, 09:28 AM   #4
Outlaw72
Hay Team!!
Outlaw72's Avatar
Yea...I did. Seems to be pretty close if not right on it.
Old 10-25-2009, 02:06 AM   #5
Super73
Super73's Avatar
Thought this might be a good stcky for people trying to figure out gear ratios and converter slip..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Old 02-27-2010, 11:33 PM   #6
82Cecil
82Cecil's Avatar
Good stuff. shows me shift points more clearly.
82Cecil is offline   Reply With Quote
Old 02-28-2010, 02:56 AM   #7
wheatlandbrawler
wheatlandbrawler's Avatar
hey super i need a richmond 5 speed added. what info do you need? just the first 1st through 5th ratios?
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 02-28-2010, 03:40 AM   #8
Super73
Super73's Avatar
1st through 5th ratios..
Old 03-14-2010, 03:03 PM   #9
wheatlandbrawler
1st 3.28
2nd 2.13
3rd 1.57
4th 1.24
5th 1.00
sorry it took so long, put this on the back burner been so busy. i appreciate it though.
Old 10-26-2010, 11:27 PM   #10
olay198912
A gearing mechanism of a motor vehicle engine that reduces the power output required to maintain driving speed in a specific range by lowering the gear ratio
olay198912 is offline   Reply With Quote
Old 11-26-2010, 01:39 AM   #11
Super73
Super73's Avatar
This is the third time I have read this on 3 different dates. Still trying to figure out what you are exactly looking for..
Old 08-09-2011, 05:15 AM   #12
1malo68
1malo68's Avatar
Here's another link that you may or may not want to use.
http://www.grimmjeeper.com/gears.html
Enjoy!
1malo68 is offline   Reply With Quote
Old 02-02-2014, 11:44 PM   #13
69restomod
Hey super 73 this is a little off topic and im brand new to the website and it seems like you really know your stuff, i have a 69 shortbed with an 11-1 built 383 built 700r4 with hardened output shaft all the goodies lockup 3600 converter 3.42 rear gears and a 30 inch tall tire,truck weighs 3600 lbs i am wanting to switch to a 4.11 or 4.30 gear and didnt know if it would be too much gear for going through the traps in 3rd gear without shifting in to overdrive? any help would be great
69restomod is offline   Reply With Quote
Old 04-01-2014, 08:34 AM   #14
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
You do not want to be in OD unless you have really have that trans built to go there.. Very few are set to handle big power in OD. Plus the drop to
Drop to a 28 in tall tire. Cheaper to test that set up for RPM. what is max RPM on the engine? A few links with gear calc programs . A 30 inch tall tire in bias or radial?? Tire growth will come into play with a bais tire if that is what you have now, my dealings has been that tire is growing at least 1-1.5 inchs on the big end
Try this one..
http://hotrodworks.net/hotrodmath/quarter.html
http://www.locost7.info/gearcalc.php
GMR-PERFORMANCE is offline   Reply With Quote
