Old 07-23-2008, 11:20 PM   #1
pugs
pugs's Avatar
57 build
Well i had started a thread about my truck before(getting my truck today)
for those that remember. well things were coming along, welded a nova clip in, chevelle rear out back and the cab had new patch panel in. overall i just wasnt totally happy with it. I had picked up this 55 parts truck
for the front sheetmetal, after taking the clip off and cleaning out the inside and really looking over it, I decided that this cab was actually better and would take less time to get into shape then the original one. so at that point i started cytting out the patch panels i had inthe cab and reinstalled them on the 55 cab, plus i did have some other floor panel patches hanging in the garage
(cab corned pics)
front cab mounts
driverside hinge pocket area(pass side is done now too)
there was some rust at top of the windsheild frame so i had cut a portion out of the other cab at the cowl area and tacked in place still need to do alittle welding and finish it off
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 07-23-2008, 11:26 PM   #2
pugs
pugs's Avatar
Re: 57 build
I did have the original cab setup with a 54 dodge dash in it so it was also cut out and is going to be use in the 55 cab
and installed a CJ7 tank out back
will get more pics this weekend pass side lower hinge plate had to be replace also, i did start stripping down the roof tonite and plan on getting the pass side cab corner done and get it primer withinthe next week
Old 07-24-2008, 12:29 AM   #3
Kim57
Kim57's Avatar
Re: 57 build
Lookin good pugs, keep up the work and pics.
Kim
Kim57 is offline   Reply With Quote
Old 07-24-2008, 07:42 AM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 57 build
I like the dash change. Adds to the personal idea.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-24-2008, 11:12 AM   #5
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 57 build
good job man. keep the pics coming.
Kabwe is offline   Reply With Quote
Old 07-25-2008, 11:00 PM   #6
pugs
pugs's Avatar
Re: 57 build
thanx guys, as far as the dash, i cut the ashtray section out of the 57 dash and welded it in where the original dodge one was, and im not sure if i want to weld the dash in or just bolt it in so it can be removed. did some more work on the truck, look how nasty the roof was on this thing
and the pass side lower hinge pocket
Old 07-27-2008, 10:04 PM   #7
pugs
pugs's Avatar
Re: 57 build
well since the fresh air vents were shot i went with ones out of a 64 chevy truck
drivers side
pass side
Old 07-27-2008, 10:11 PM   #8
pugs
pugs's Avatar
Re: 57 build
got the dash bolted down mounted the mc/booster boltedin and the steering column in place still debating on a 23" lokar floor shifter
Old 07-27-2008, 10:50 PM   #9
OrrieG
OrrieG's Avatar
Re: 57 build
That dash is going to be cool! Lots of folks will not know the difference but those that do will take a double or triple take. Did the ends fit or was it wider and that is where you trimmed it to match the cab?? Also, looking at the rust issues you are dealing with I have a greater appreciation of how good my cab is!
OrrieG is offline   Reply With Quote
Old 07-27-2008, 11:43 PM   #10
pugs
pugs's Avatar
Re: 57 build
actually the dash was abit narrower the the stock one but i used the endes of it to blend in, will get pics this week, still nee to work on finishing it off right and make it flow together, as for rust alot of surface but the original cab i started with was alot worse then this one
Old 07-30-2008, 11:20 AM   #11
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 57 build
Looking good pugs.
Old 08-11-2008, 09:40 PM   #12
pugs
pugs's Avatar
Re: 57 build
ok guys alittle update on the project, here's a couple of pics of the dash with the gauges in place
was out to Carlisle to the truck nats this past friday, was looking for patch panels for the front fenders, couldnt believe it none to be found. So while walking around i did find a pr of 57 fenders which were really decent and solid at the rear brace area so i scarfed them up. the pass side was abit of a mess at the headlite area, so i cut a section out of a junk fender i had here and fixed it all up. dont think it came out to bad, will get other progress pics this week
Old 08-11-2008, 10:12 PM   #13
pugs
pugs's Avatar
Re: 57 build
couple more pics, also got most of the floor and the lower rear panel in primer
the whole cab will be sprayed in grey sand amd fill primer (hopefully soon)
Old 08-11-2008, 10:23 PM   #14
poncho_villa
poncho_villa's Avatar
Re: 57 build
I didn't really appreciate that dash too much until I saw it with the gauges. That looks real good and very functional too. Nice and easy to read.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 08-11-2008, 10:40 PM   #15
pugs
pugs's Avatar
Re: 57 build
that was the reason i used the dash cuz the gauges were in place and heck i only payed $30 for it all, will be working on a floating center grill sention this week
Old 08-12-2008, 07:35 AM   #16
entourageguy
Yellow truck club
Re: 57 build
That dash will get the 55-59 guys to take a 2nd look.
Looks great.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-12-2008, 09:18 PM   #17
pugs
pugs's Avatar
Re: 57 build
found the mesh to use so i can do the floating center onthe truck grill
fender spear inthe center
http://i30.photobucket.com/albums/c3...a/SANY1208.jpg
thought about using this GMC hood to maybe to a fresh/cold/ram air setup but not possitive on the look
Old 08-13-2008, 01:43 AM   #18
Kim57
Kim57's Avatar
Re: 57 build
I like the grill Pugs. I'm going for the same look on my 57. Where did you get the mesh?
Kim
Old 08-13-2008, 02:33 PM   #19
pugs
pugs's Avatar
Re: 57 build
picked up the mesh at a local weld/metal shop, dont know the cost yet as the guy i deal lets me the price of things a few days later
Old 08-19-2008, 09:24 PM   #20
pugs
pugs's Avatar
Re: 57 build
went to the local u-pull-it on Sunday morning and picked up i van tilt & ign switch
also been working on the dash trying to get the ends looking even where the 54 dash is blended to part of the stock truck dash, need alittle fenesing but its getting there
Old 08-20-2008, 12:53 PM   #21
55dude
55dude's Avatar
Re: 57 build
cool stuff so far dude! that dash really i killer!
55dude is offline   Reply With Quote
Old 08-20-2008, 01:29 PM   #22
54 jimmy
54 jimmy's Avatar
Thumbs up Re: 57 build
i think that you have a really good idea with the gmc hood. haven't seen that done before. looks great to me but that's just my 2 cents. keep up the good work.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-21-2008, 02:56 AM   #23
Daniel U
Daniel U's Avatar
Re: 57 build
I agree, that cold or cool air intake is a neat idea! Ram air into the carb or throttle body.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 08-21-2008, 10:57 AM   #24
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 57 build
Nice work man!
CAL 58 GMC is offline   Reply With Quote
Old 09-20-2008, 12:32 PM   #25
55dude
55dude's Avatar
Re: 57 build
time for a project update, what cool stuff have you been doing to your truck?
