Old 01-08-2010, 03:06 AM   #1
76whitelightnin'
Steering Question..
I recently lifted my 76 and need a drop pitman arm. its a 6" lift and the only drop pitman arms a can find are for 4" lifts. because with the stock one i can drive but its really puttin a hurtin on my steerin linkage. Any companys i could go with?
Much thanks.
76whitelightnin' is offline   Reply With Quote
Old 01-08-2010, 09:40 AM   #2
Re: Steering Question..
I`ve never seen a drop pitman arm,only drag links and steering arms off the knuckle.The steering arms are sold as 4-6" lift.That`s what I always do.I don`t like the dropped drag link because it`s supposed to be straight and being bent causes more roll against the joints which makes increased side stress.
Old 01-08-2010, 10:58 AM   #3
Burt4x4
Burt4x4's Avatar
Get some pics posted of your current setup. www.wfoconcepts.com makes custom sterring setups and has great service to make sure it is the right setup for your rig.
Have you looked into doing a crossover setup?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-09-2010, 04:09 AM   #4
76whitelightnin'
I have never really looked into the crossover setup. but from the looks of it the drop pitman arm that WFO has looks like it will work. ill get some pictures up soon, but we did a little modifying to the drag link, and yeah. i can drive it now, but with the worst bump steet i have ever felt on anything.
thanks a million.
Old 01-09-2010, 09:38 AM   #5
I used a steering arm on a 6" lift and bump steer is about non-existent.The plan was for crossover/high steer,but I sold it.Did you center your steering box?
Old 01-09-2010, 06:27 PM   #6
76whitelightnin'
yeah, because i know that makes a big difference. but here is a picture to give you guys an idea of the angle. im sure if i corrent it i will be good to go.
