Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-27-2012, 01:59 PM   #1
gofastnut
gofastnut's Avatar
Got my Eastwood Poweder Coat Kit today...
I was really happy opening up the box and checking out the stuff.
And then it happened. I was flipping through the magazine that came with it and found the same kit(1 more powder) on sale for $99!
So I called em. Got this chap named Rob-british accent. Told him my sad story and waited to see what he had to say.
He put me on hold for a minute, then came back and said I had a $50 credit!
I didn't really care about 1 more color, I was kinda miffed about the 50 bucks, so now I've got $50 more to spend!
Probably buy a starter soda blaster kit to go with my starter media blaster kit.
Anyone in Sacramento area have a good, free electric oven?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-29-2012, 04:57 PM   #2
Glorybound13
Junior Member
Glorybound13's Avatar
Re: Got my Eastwood Poweder Coat Kit today...
That's some pretty good customer service there. Definitely let us know how it works. I've been interested in that kit to do some of the brackets and all on my truck. Good luck!
Glorybound13 is offline   Reply With Quote
Old 03-02-2012, 06:26 PM   #3
gofastnut
gofastnut's Avatar
I'm building a DIY (read cheap) Blast cabinet. I'll post pics of the cabinet and something I've powdercoated when I'm done. Right now work, school and my daughter's 4th grade California Mission project are taking up ALOT of my time.
I'll keep ya posted.
Jeff
C-10 Club
Old 03-04-2012, 04:41 AM   #4
zicc1835
zicc1835's Avatar
i got the kit a while ago picked up an old elec oven havnt tried it yet i will be interested to see how you do ....i will stay tuned or post when i get around to trying my hand at it
zicc1835 is offline   Reply With Quote
Old 03-04-2012, 11:39 AM   #5
blazer2007
was wondering if you could use a toaster oven for small jobs
blazer2007 is offline   Reply With Quote
Old 03-05-2012, 12:37 AM   #6
zicc1835
zicc1835's Avatar
at first you made me laugh actually a big smile i thinks thats a great idea get a grill thermometer and see if will get to 400 degrees and stay there...why didnt it think of that
Old 03-05-2012, 12:54 AM   #7
Notch1988
Notch1988's Avatar
My neighbor uses a toaster oven for his small snowmobile parts. Seems to work just fine.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 03-05-2012, 03:23 PM   #8
gofastnut
gofastnut's Avatar
OK, All I've got is a toaster oven, and it's small, but I'll post a couple of pics later.
Jeff
C-10 Club
Old 03-05-2012, 04:35 PM   #9
gofastnut
gofastnut's Avatar
So here's what I've got:
You can see the custom made hanging device I gabbed up using a ball pein hammer stuck in the end of the hyd jack handle.
The first coat I applied to the puller was only about 1.5 psi-perfect for little parts. Then I went up to the recommended 8 psi and wound up using alot more powder and making alot more dust. which just blows right off BTW. The pic of my fat hand holding the puller is trying to show the lack of coverage in the "crotch" of the V. I would hang it how I'm holding it if I did another one. The key is for my saturn. I put some foil around it and dusted it. I used a 13/16" socket, stuck the key in the 3/8 drive hole and shimmed it up with a wad of foil. You can also see my "Custom Deluxe" toaster oven that I used. It's about 9"W x 6"D x 3.5"H. I had to lay the puller center down on the rack in it, so now I've got a couple of bare spots where it touched the grate.
Jeff
C-10 Club
Old 03-05-2012, 04:39 PM   #10
gofastnut
gofastnut's Avatar
Oh, I took the puller out after the 20 min @400 deg, hung it back up and coated it again. It came out mucho smooth-o, or as some would say "Smoother than mules lips". I didn't prep the metal finish wise, except to clean off the rust and wipe it with acetone.
I've got to get a better set-up, which requires a clean garage and a bigger oven. I'm gonna make a hanging stand out of some old 1" pipe & fittings I've got laying around.
I've already got people wanting me to coat stuff, and I'm not really set up yet!!
Jeff
C-10 Club
Old 03-05-2012, 08:01 PM   #11
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I use a home oven that I bought for 100 bucks works great. Get your self some heavy wire to make a few hooks. I have seen a few guys build a home srpay booth with 20 twenty inch box fans a couple of 2 buck screens for your home heating system and a bow fridge box. I was shocked at how good it really worked. Some PVC and sheeting will get the job done and some racks to hang parts.
I can tell you metal prep is the very important for a great gloss finish. CLEAN CLEAN CLEAN parts, pre heat to cook off anything that wants to pop to the surface. Let it cool while the oven stays hot get the metal down to a temp where the powder does not melt , but it will stick like a mother for you.
I have done tons of stuff on my truck, the intake, valve covers, rear diff covers, upper and lower a arms, ..if you can fit it into the oven it gets PC'D .. Super tough finish that will last much longer than paint.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-05-2012, 09:08 PM   #12
shoooter
where did you get this kit for 100 bucks? what brand?
shoooter is offline   Reply With Quote
Old 03-05-2012, 09:41 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I think I'm going to have to get one of these now too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-05-2012, 10:56 PM   #14
gofastnut
gofastnut's Avatar
Re: Got my Eastwood Powder Coat Kit today...
It's from Eastwood. They've got a sale in the front inside cover of their little sales flyer. The $150 kit is on sale for $99. The only difference is you don't get to pick your powders.
GMR PERFORMANCE I can't put hooks in this cute lil toaster, but I'm trying to get something bigger lined up that I can use, so I won't have bare spots on something that's coated both sides.
Jeff
C-10 Club
Old 03-06-2012, 10:33 AM   #15
GMR-PERFORMANCE
If you can get some scap stell and put slef tappers through it you can coat the side you dont see HA HA carefully pick it up and flip it over and then coat the other side. Home ovens are cheap most go for 50-100 bucks. You dont need anything fancy.
Old 03-06-2012, 03:36 PM   #16
cannaert
SWEET DEAL. I need to go order on of them kits and some flat black powder so I can do a bunch of bike parts for another little project I got going on.
Good to know they are cool about stuff like that at Eastwood.
cannaert is offline   Reply With Quote
Old 03-06-2012, 04:51 PM   #17
shoooter
Do you have a website for this company?
Old 03-06-2012, 06:29 PM   #18
gofastnut
gofastnut's Avatar
Here you go:
http://www.eastwood.com
Look under the tab "Powdercoating", then look to the left margin, it's listed out as "kits", "powders", etc.
Jeff
C-10 Club
Last edited by gofastnut; 03-06-2012 at 06:31 PM. Reason: I was being a smart ass and decided not to.
Old 04-27-2012, 09:29 PM   #19
Weasel Diesel
I have the little eastwood kit and love it. I am getting ready to do my rims now. I have been practicing with it coating all sorts of stuff. My wife says my shop is too colorful now. I told her move on cause she'd look good in Chevrolet Orange.
Weasel Diesel is offline   Reply With Quote
Old 04-28-2012, 11:01 PM   #20
Leonard1
Leonard1's Avatar
If you check out ebay, Eastwood has the gun only listed for $59.99 with free shipping.
Leonard1 is offline   Reply With Quote
Old 04-05-2013, 03:02 PM   #21
gofastnut
gofastnut's Avatar
So, two moves and A LOT of stuff later, I'm still just getting my powdercoating together. I just got 220volts wired into the garage, so I'll see shortly.
Jeff
C-10 Club
Old 04-05-2013, 03:27 PM   #22
hyatt
I bought one of these several years back Powercoated engine brackets,pulleys door and hood hinges valvecovers etc Works great
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 04-07-2013, 09:36 PM   #23
gofastnut
gofastnut's Avatar
That's my goal, hyatt.
Jeff
C-10 Club
Old 04-08-2013, 08:16 AM   #24
Sammy
Check Craigslist for a oven. I see them all the time for free after getting a replacement they just want them gone n not pay for them to disappear.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-08-2013, 12:14 PM   #25
gofastnut
gofastnut's Avatar
Appreciate the tip, Sammy!
Jeff
C-10 Club
powder coat, powdercoat, powdercoating
