Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-28-2013, 01:36 AM   #1
DG Racing
DG Racing's Avatar
Question Gmc c60 1988
How wide is the front track of a 1988 c60 ?
because if its the same as my 1959 C 80 i will be interested to change my frame on my truck for a 1988 c60 that i can purchase cheap
DG Racing is offline   Reply With Quote
Old 06-29-2013, 12:51 PM   #2
DG Racing
DG Racing's Avatar
Re: Gmc c60 1988
Or maybe how wide is a c-60 1975 ?
Old 06-29-2013, 09:22 PM   #3
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: Gmc c60 1988
I'm not sure, but that seems like a real nice original heavy truck in real nice condition.
You have something pretty special there.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 06-30-2013, 03:53 PM   #4
Flat 67
Junior Member
Flat 67's Avatar
Re: Gmc c60 1988
Mr. DG
A 1988 GMC 7000 has a front track of 81 inch, center of tire to center of tire. I hope this helps. What are your plans?
Flat67
Flat 67 is offline   Reply With Quote
Old 07-01-2013, 01:56 PM   #5
DG Racing
DG Racing's Avatar
Re: Gmc c60 1988
Ok thank for the specs .Flat 67
but the 1988 is to wide for my 1959 because me I have 71 inch so that is 10 inch extra for the 1988 .
I wanted to buy a 1988 c60 and remove the body to install my 1959 body on it . like that I would have newer mechanic , brake ,diff ,tire etc.. all in one shot .
Is a 1988 C60 is the same as a 1988 GMC 7000 ?
Old 07-01-2013, 08:12 PM   #6
mrolds88
Re: Gmc c60 1988
DG, you may still be able to update your truck. There was a post on here about C-60 axle/suspension. While the track is no good for you, the spindles, brakes and such MAY swap. If the axle weight rating is the same you may be able to do it. The rear axles, I can't say for sure. You have a nice looking truck. I had a similar, but bigger 59 a few years ago. It was a 348/5speed/2/speed setup. It was a 10400 series. Wish I never got rid of that thing.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-02-2013, 02:08 AM   #7
Flat 67
Junior Member
Flat 67's Avatar
Re: Gmc c60 1988
Originally Posted by DG Racing View Post
Is a 1988 C60 the same as a 1988 GMC 7000 ?
There are several spring rating, but a C60 is the same as a GMC 7000.
Also like mrolds88 said , have you considered narrowing the front axle?
Check out this YouTube video about a company called Kelderman on a project by Stacy David on Gears.
http://www.youtube.com/watch?feature...&v=woUdGkOsQco
Old 07-02-2013, 02:36 AM   #8
Flat 67
Junior Member
Flat 67's Avatar
Re: Gmc c60 1988
DG
"1966 Snub-nose C60 project" is planning on narrowing his front axle 8 inch
Flat67
Old 07-02-2013, 10:42 AM   #9
mrolds88
Re: Gmc c60 1988
Actually what I wqas thinking was to swap the newer spindle units onto the original axle.
93 K2500 xcab 6.5TD
Old 07-06-2013, 12:27 AM   #10
DG Racing
DG Racing's Avatar
Re: Gmc c60 1988
thanks guys for the info but I think I will go in a different route then with the c-60 1988
