Carb porn
My new 950 AED competion super mod. Getting all my new stuff together.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
mini truck racer
Re: Carb porn
Very nice . A good carb can change your race program .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: Carb porn
Nice carb let us know how much better it does.
meowMEOWmeowMEOW
Re: Carb porn
Where do I put the fuel injectors? Your 4150 looks broken.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Carb porn
I am set to add EFI but I am waiting I look hard at the Holley dominator set up and XFI but really spendy Fast has an updated system that will be like the 2.0 EZ system but will be called the sportsman as it will allow manual tuning with the lap top for engines with larger cams etc.. But if you want to sponsor me I will take a XFI set up with intake I can PM you the mailing address HA HA
Re: Carb porn
This is an older thread but here is my carb. Its called a 4825. They dont rate them in cfm , rating is off venturi and throttle bore size. This is not my actual carb but the info David sent me originally. Its a real unique piece.
It's Better With Nitro
Re: Carb porn
I used to run a Braswell on my Super Gas car. Here my custom Performance Carburetor, built by my buddy, Eddie Leabo, for the C10.
