Old 03-14-2015, 11:18 AM   #1
tinkerdad
fuel line info needed
I’ve got a 2002 6.0L engine going into my 70 with the fuel tank and pump in the rear. I’m looking for suggestions on where to purchase my fuel supply and return lines and filter.
tinkerdad is offline   Reply With Quote
Old 03-14-2015, 02:01 PM   #2
H20cooled
Re: fuel line info needed
I used the info in the FAQ on Fuel and bought most of my stuff from Summit and Amazon which ever was cheaper. It's still not cheap but it worked out great.
H20cooled is offline   Reply With Quote
Old 03-14-2015, 03:26 PM   #3
tinkerdad
10-4 thanks. I'll go there, forgot about that resource.
Old 03-15-2015, 05:41 PM   #4
Robznob11
Robznob11's Avatar
I went to the pick and pull with a tubing cutter and cut 6 ends off of donor trucks, I left enough steel so that I could use double flares and inverted brass connectors. You can borrow the double flare tool from AutoZone or orylies. Napa sells the brass inverted connection s. Yo Cain use stock lines or do like me. I bought a 25 foot roll of 3/8 coated fuel line cheap at auto zone. I run a inline fuel filter from Wal-Mart. The 3/8 push connectors fit right on it. I'm also running a 02 camaro fuel tank and pump
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-15-2015, 05:55 PM   #5
tinkerdad
That is a smart way to get it done! Thanks
Old 03-16-2015, 11:16 AM   #6
mattcrp1
mattcrp1's Avatar
I used the Dorman nylon fuel line kit and summit heat sleeve (on the run up to the back of the engine), it is just like the factory stuff on new cars.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-20-2015, 02:52 PM   #7
72c10suburban
72c10suburban's Avatar
Got a pic of the filter or a part number? Is it 3/8" quick connect on both ends? Im planning on the Dorman nylon line as well and I'm trying to sort out what type of filter to run after the Walbro 255.
72c10suburban is offline   Reply With Quote
Old 03-20-2015, 03:22 PM   #8
Robznob11
Robznob11's Avatar
Here you go
LED TAILS
