#276 |
the pollock
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
show off...
hehehhe what about saab and subaru steering? they are narrow like that little car... and saabs ar ea dime a dozen now in the junk yards..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 09-18-2009 at 07:37 PM. |
#277 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Why not just make it right hand drive???? mmmmmmmmmmmmmmm
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#278 |
GEARHEAD
What about something like a 4x4 cross over steering? Except maybe cross under steering.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#279 |
the pollock
<<<commentary removed by me due to it being retarded and time for me to go to sleep.... stupid pills...>>>>>>
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 09-18-2009 at 10:51 PM. |
#280 | |||
![]() Join Date: Aug 2005
I thought about it for a few seconds but I JUST finished off the PS firewall...
![]() Quote:
#281 | |
Enjoying left field
[IMG] ![]() They mount to the firewall, but the tie rods cross over the crossmember. This one's in my GMC, but I don't think I'm gonna use it. Let me know if you need any dimensions or anything. Last edited by woodwright; 09-21-2009 at 02:15 AM. |
#282 |
Great tip! Thanks! I will look into those. I'd really like to stay manual if I can.
#283 |
if you need a RHD rack, i have one sitting in the clip i got for my 20V swap still. i'd be willing to donate it
![]() also you could look at a 84-87 RWD corolla. some of them had manual racks that are pretty thin. also Techno Toy Tuning has an adapter that allows you to use an 84-87 MR2 manual rack in those corolla's so i'm sure it can be adapted to your needs ![]() i forgot to mention i saw a rack setup that uses the center links like you have posted in your pics in one of my latest superchevy or chevy high performance mags for camaro/nova. i gotta go find the add when i get home but i'll post a link if they have it.
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 ![]() Last edited by Jvsapp; 09-21-2009 at 11:22 PM. |
#284 |
Gearhead
FF I saw a few ads for a similar set-up to what you are looking for, the Unisteer system (unisteer.com) and Flaming River has a few systems too. Just thought I would mention it.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#285 |
Thanks. You are absolutely right. I am currently working with Unisteer to design a custom rack. They are a little behind the curve though (or at least the rep I'm dealing with is). Their custom rack spec form only applies to end-steer (conventional) racks yet they insisted I fill one out. So I modified their form to apply to a center-steer rack and gave them my specs. Waiting to hear back...
I might try Flaming River if Unisteer fails. Last edited by Frizzle Fry; 09-24-2009 at 01:56 PM. |
#286 |
Gearhead
Glad to hear it, figured you were already on it from the looks of the build. Good luck with the set-up, hope you get something figured out soon.
#287 |
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 ![]() |
#288 |
I may have some more info for ya FF. This weekend I had to change the hydraulic throw out bearing, (slave cylinder), in our beater. ( 95 Chevy Beretta).
Anyway while I was in there I noticed it has a center steer rack similar to the Intrepid one woodwright posted. Dunno if it'd help ya out any but I thought of this thread when I seen the beretta rack... LOL
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#289 |
Well, I have "someone in the industry" dealing with Unisteer for me now. It seems they are undermanned in a big way. Had to pull some strings to get things moving with them. Actually he offered and I am very thankful.
![]() The Baretta rack is rear steer I believe, just like the cavalier. The center take-off (as I have learned it's called) is indeed what I am looking for. But if you use a rear steer rack as front steer you get reversed steering ![]() Progress slowed over the last couple weeks. Been working tons of OT at work which is great for the toy budget, but bad for toy time... My straight die grinder also died which has slowed the DS inner fender work. I should post pics of the header work I did. I also did some work on the steering column/firewall passthrough. Boxed the lower link brackets on the rearend and installed it again. Plasma cut a hole to fit the S2000 shifter in the Minx floor hump/tunnel. ...and continue to pursue a steering rack... ![]() |
#290 | |
Come on, where your sense of adventure.... reversed steering would just take a few minutes to get used to...LOL And nobody would steel it, (and get away with it that is)...hahaha And the search continues.... I tried...LOl ![]() ![]()
#291 |
Mike
I know this is a little off the base but today I almost ran off the road looking at what appeared to be your exact same car same color same red trim and wheels. Hard to believe. It was in excellent shape.looked fully restored or very good original. If I hadn't been going the opposite direction I would have chased him down.
the avatar was my 62 I owned for 27 years 84 chevy short short bed black 84 gmc long bed copper/ buckskin 88 chevy k5 blazer white Life's short make the most of it Mark aka impalmark Last edited by impalamark; 10-19-2009 at 09:41 PM. |
#292 |
Haha! That's awesome! That's probably the only other one like it in the country (paint scheme and all). It may have been badged a Hillman (same car, different name). Very cool that you noticed
#293 |
FF, something to think about
![]() Last edited by Frizzle Fry; 10-20-2009 at 11:38 PM. Reason: no change... |
#294 |
#295 |
Long overdue update. Not much progress of late but here's what I've got. Some of these were mentioned before but here's the pics to back it up...
#296 |
The whole point of that header work was to tuck it in tighter. Worked out pretty well:
![]() Added a little boxing to the lower link brackets: ![]() ![]() ![]() ![]() Playing with shifter/tunnel placement: ![]() Orange on the steering wheel is just tape for protection: ![]() ...and a possible placement for a clue to what it's packin ![]() ![]() ![]() |
#297 |
Under Construction
looking good Mike!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#298 |
PROJECT 7DEUCE
She is really looking good....
#299 |
Ahhh! I needed that fix! Withdrawal symptoms suck!
![]() Thanks!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#300 |
1 thing at a time is progress.
Beautiful work!!
Alan
Philippians 2:14-16 |
