Old 09-18-2009, 07:36 PM   #276
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
show off...
hehehhe
what about saab and subaru steering? they are narrow like that little car...
and saabs ar ea dime a dozen now in the junk yards..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-18-2009, 09:13 PM   #277
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Why not just make it right hand drive???? mmmmmmmmmmmmmmm
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-18-2009, 10:27 PM   #278
hgs_notes
GEARHEAD
hgs_notes's Avatar
What about something like a 4x4 cross over steering? Except maybe cross under steering.
hgs_notes is offline   Reply With Quote
Old 09-18-2009, 10:50 PM   #279
dammitmitchell
the pollock
<<<commentary removed by me due to it being retarded and time for me to go to sleep.... stupid pills...>>>>>>
Army vet 02-08
Old 09-20-2009, 12:34 AM   #280
Frizzle Fry
Frizzle Fry's Avatar
I thought about it for a few seconds but I JUST finished off the PS firewall...
Originally Posted by dammitmitchell View Post
show off...
hehehhe
I'll take a look at them
hmmmmmmm
Frizzle Fry is offline   Reply With Quote
Old 09-21-2009, 02:11 AM   #281
woodwright
Enjoying left field
woodwright's Avatar
Originally Posted by Frizzle Fry View Post
The problem is that all the center steer units I can find are designed for rear steer. I may end up getting a RHD rear steer unit and using it for LHD front steer... We'll see.
A center steer from a 94ish Dodge intrepid would be correct.
[IMG][/IMG]
They mount to the firewall, but the tie rods cross over the crossmember. This one's in my GMC, but I don't think I'm gonna use it. Let me know if you need any dimensions or anything.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 09-21-2009, 04:34 PM   #282
Frizzle Fry
Great tip! Thanks! I will look into those. I'd really like to stay manual if I can.
Old 09-21-2009, 10:46 PM   #283
Jvsapp
Jvsapp's Avatar
if you need a RHD rack, i have one sitting in the clip i got for my 20V swap still. i'd be willing to donate it
also you could look at a 84-87 RWD corolla. some of them had manual racks that are pretty thin. also Techno Toy Tuning has an adapter that allows you to use an 84-87 MR2 manual rack in those corolla's so i'm sure it can be adapted to your needs
i forgot to mention i saw a rack setup that uses the center links like you have posted in your pics in one of my latest superchevy or chevy high performance mags for camaro/nova. i gotta go find the add when i get home but i'll post a link if they have it.
Jvsapp is offline   Reply With Quote
Old 09-23-2009, 02:35 PM   #284
6772owner
Gearhead
6772owner's Avatar
FF I saw a few ads for a similar set-up to what you are looking for, the Unisteer system (unisteer.com) and Flaming River has a few systems too. Just thought I would mention it.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-24-2009, 12:58 AM   #285
Frizzle Fry
Thanks. You are absolutely right. I am currently working with Unisteer to design a custom rack. They are a little behind the curve though (or at least the rep I'm dealing with is). Their custom rack spec form only applies to end-steer (conventional) racks yet they insisted I fill one out. So I modified their form to apply to a center-steer rack and gave them my specs. Waiting to hear back...
I might try Flaming River if Unisteer fails.
Old 09-24-2009, 09:17 AM   #286
6772owner
Gearhead
6772owner's Avatar
Glad to hear it, figured you were already on it from the looks of the build. Good luck with the set-up, hope you get something figured out soon.
Old 10-05-2009, 11:21 PM   #287
Jvsapp
Jvsapp's Avatar
figure i stir this post again... looking for inspiration
Old 10-05-2009, 11:59 PM   #288
454_72_4X4
454_72_4X4's Avatar
I may have some more info for ya FF. This weekend I had to change the hydraulic throw out bearing, (slave cylinder), in our beater. ( 95 Chevy Beretta).
Anyway while I was in there I noticed it has a center steer rack similar to the Intrepid one woodwright posted. Dunno if it'd help ya out any but I thought of this thread when I seen the beretta rack... LOL
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 10-06-2009, 01:12 AM   #289
Frizzle Fry
Well, I have "someone in the industry" dealing with Unisteer for me now. It seems they are undermanned in a big way. Had to pull some strings to get things moving with them. Actually he offered and I am very thankful.
The Baretta rack is rear steer I believe, just like the cavalier. The center take-off (as I have learned it's called) is indeed what I am looking for. But if you use a rear steer rack as front steer you get reversed steering
Progress slowed over the last couple weeks. Been working tons of OT at work which is great for the toy budget, but bad for toy time...
My straight die grinder also died which has slowed the DS inner fender work.
I should post pics of the header work I did.
I also did some work on the steering column/firewall passthrough.
Boxed the lower link brackets on the rearend and installed it again.
Plasma cut a hole to fit the S2000 shifter in the Minx floor hump/tunnel.
...and continue to pursue a steering rack...
Old 10-06-2009, 01:21 AM   #290
454_72_4X4
454_72_4X4's Avatar
Yep, you are correct. the beretta is rear steer. I forgot about where you needed the rack placed.
Come on, where your sense of adventure.... reversed steering would just take a few minutes to get used to...LOL And nobody would steel it, (and get away with it that is)...hahaha
And the search continues.... I tried...LOl
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 10-19-2009, 09:41 PM   #291
impalamark
impalamark's Avatar
Mike
I know this is a little off the base but today I almost ran off the
road looking at what appeared to be your exact same car
same color same red trim and wheels. Hard to believe. It was in excellent shape.looked fully restored or very good original.
If I hadn't been going the opposite direction I would have chased him down.
the avatar was my 62 I owned for 27 years
84 chevy short short bed black
84 gmc long bed copper/ buckskin
88 chevy k5 blazer white
Life's short make the most of it
Mark aka impalmark
impalamark is offline   Reply With Quote
Old 10-20-2009, 01:06 AM   #292
Frizzle Fry
Haha! That's awesome! That's probably the only other one like it in the country (paint scheme and all). It may have been badged a Hillman (same car, different name). Very cool that you noticed
Old 10-20-2009, 06:50 PM   #293
felixthecatjr
felixthecatjr's Avatar
FF, something to think about
felixthecatjr is offline   Reply With Quote
Old 10-20-2009, 11:38 PM   #294
Frizzle Fry
mmmm, Nice. Check this out.
Old 10-21-2009, 12:09 AM   #295
Frizzle Fry
Long overdue update. Not much progress of late but here's what I've got. Some of these were mentioned before but here's the pics to back it up...
Old 10-21-2009, 12:20 AM   #296
Frizzle Fry
The whole point of that header work was to tuck it in tighter. Worked out pretty well:
Added a little boxing to the lower link brackets:
Playing with shifter/tunnel placement:
Orange on the steering wheel is just tape for protection:
...and a possible placement for a clue to what it's packin
Old 10-21-2009, 08:05 AM   #297
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Mike!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-21-2009, 10:29 AM   #298
FRENCHBLUE72
PROJECT 7DEUCE
She is really looking good....
MEMBER #6377
Project "7DEUCE"
Old 10-21-2009, 03:34 PM   #299
ERASER5
ERASER5's Avatar
Ahhh! I needed that fix! Withdrawal symptoms suck!
Thanks!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-21-2009, 10:32 PM   #300
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Beautiful work!!
Alan's Classic is offline   Reply With Quote
