10-26-2011, 04:39 AM | #1001 |
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Frizzle,
It's a Rapier Fastback (Alpine in the U.S) 1969 vintage. Based on the Hillman Hunter wagon/estate. NONHOG Build thread would be difficult,it's been off the road for 14 years!!? Very slow project watahyaknow Windsor motor is a great package for conversions, distributor @ front, small dimesions. Would really like to use a toyota (shock,horror) 1uz v8 but width kills them. Larry (actually an Oz G.M. fan but anything done right will do) |
10-27-2011, 12:32 AM | #1002 | |
10-27-2011, 01:42 PM | #1003 |
Back in the game. The following update took WAY too many hours, mostly due to mistakes and rework, but I'm happy with the results thus far.
Rear brake caliper brackets. First iteration was fwd facing. Looked good except one minor detail: they blocked the coilovers Fortunately with a little rework I was able to flip them to the rear and all clears: |
10-27-2011, 01:46 PM | #1004 |
Still Learning
Very cool work on the brakes. You may have already said, where did you get the mounting plates and what are the calipers from? the donor? Keep the pics coming.
sorry to hear about the rework......I know how much time this kind of stuff takes. |
10-27-2011, 02:13 PM | #1005 |
Part of the reason I placed the calipers in the front was to accommodate the e-brake cables. They now faced the wrong way:
Since no performance car is complete without a functional turning brake the ebrake cables/brakcets/belcranks had to be reconfigured (lots of rework here too) Once the cables were pointing in the right direction, I needed a fun-lever to pull them. I looked at reusing the stock piece, and as novel as it was being on the left of the driver, I never really got used to it there. I looked at relocating it to the center, but it was too long and would have had to mount basically under the seat to put the handle in reach... So yet another S2000 piece found it's way into the mix. I made a platform mount for it and reworked the lever mounts themselves to obtain an angle/height that works with the trans tunnel: |
10-27-2011, 02:18 PM | #1006 |
Fab'ed the brackets. Calipers and rotors are all S2000. This approach keeps the world of S2000 aftermarket parts not only an option, but a requirement
10-27-2011, 02:20 PM | #1007 |
VA72C10
Nice work! and
Looking for a 67-72 swb or blazer project in or around VA. |
10-27-2011, 02:49 PM | #1008 |
67cheby
amazing work ....AS EXPECTED !!
10-27-2011, 04:01 PM | #1009 |
Sweet! Everybody loves e-brake slides. Your sunbeam will be starring in the next Fast & the Furiouster movie.
10-28-2011, 03:25 AM | #1010 |
I can not believe how great this car is turning out! Frizzle you have done one amazing job so far!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-28-2011, 03:49 AM | #1011 |
Local Redneck Authority
You might wanna think about taking the keys outta that thing at night... I wouldn't want to have it be that easy when I come to pick it up...
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
10-28-2011, 07:48 AM | #1012 |
GEARHEAD
The way the tranny tunnel is notched right there is like it was built exactly for it. Looks outstanding.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
10-28-2011, 02:36 PM | #1013 |
the pollock
hey brother.. i need help with floor pans.. a mini tub and a modification on my truck floor pan...
just sayin.. i dont wanna order just a kit to do it all.. there's TONS of wasted space on camaros... come fly down and visit for a week. i'll feed you at least once and let you pet my dogs. ha ha ha
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
10-29-2011, 04:30 AM | #1014 | |||||
Thanks Cheb! Quote:
10-29-2011, 11:45 AM | #1015 | |
10-30-2011, 09:46 AM | #1016 |
11-03-2011, 12:15 PM | #1017 |
dang FF. now that looks so clean! don't forget i called shotgun first
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
11-04-2011, 03:41 AM | #1018 |
11-04-2011, 03:49 AM | #1019 |
Redneck Hillbilly
Man, this this is just plain crazy. I love looking through the updates, and can't wait to see it finished.
11-04-2011, 03:57 AM | #1020 |
Little bit more on the ebrake-
Cable bracket mount pad: This is the stock Honda coupler. It is to be crimped over the cables. Will crimp on final install: Extended rod in stainless and added a Z-bend (RC airplane technology). I'll likely make a cover for the rod so it's not visible from the rear seat: Since one of the cable holes went through two layers of sheetmetal (only half the hole) I added half of the appropriately sized washer and a full washer on the lower hole to even it out: The uniform surface is required for a good seal with the orings: ...and made the caliper bracket spacers permanent. |
11-04-2011, 04:10 AM | #1021 |
On to the rear sway bar (a must-have with such a stout front bar)
I cut up a 3rd gen Camaro/Firebird rear bar I had in the parts bin. Shortened by 1.5" and reclocked the diff clearance/ends. Note: all length removed from driver's side due to the offset diff D44: Burned in and smoothed out: Tube-stock begets bracket (focus fail, I know) x2: Chillin at the bar: and tacked in (end-links next) |
11-04-2011, 06:03 AM | #1022 |
That's so awesome!
11-04-2011, 09:29 AM | #1023 | |
as for the rear sway, does the stock F-body go backwards too? or did you do that for clearance and room? are you going to do the standard bushings on a bolt for the end link? i got a set of nice blue poly bushings and links for my father in law's ranger front from rock auto. it was $20 for the set i think and really nice.
11-04-2011, 12:07 PM | #1024 |
Frizz, I am going to need your address so I can send the ADOPTION papers. After all, "first" after family " should include adoptees right?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
11-04-2011, 12:37 PM | #1025 |
The brackets that attach the sway bar to the axle are really clean!
