Old 01-09-2024, 06:17 PM   #26
Shifty One
Shifty One's Avatar
Re: Chev-odge: ‘71 K20 Cummins build
Is that bolt from one of these?
https://www.pdrdiesel.com/product/pd...dowel-pin-tab/
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-10-2024, 01:16 AM   #27
fishnixon
fishnixon's Avatar
Originally Posted by Shifty One View Post
Nope…check picture #14. The dowel pin is still there. Thanks for tuning in!
fishnixon is offline   Reply With Quote
Old 01-10-2024, 12:00 PM   #28
Shifty One
Shifty One's Avatar
Good time to do it it though...
Old 01-11-2024, 01:23 AM   #29
fishnixon
fishnixon's Avatar
Yup…going to cover it.
Old 01-11-2024, 10:50 AM   #30
Shifty One
Shifty One's Avatar
Then rock-on Amigo!
Old 01-17-2024, 04:01 PM   #31
fishnixon
fishnixon's Avatar
At the machine shop, it’s cleaned up and passed magnaflux testing
Old 01-17-2024, 04:03 PM   #32
fishnixon
fishnixon's Avatar
Bored .020 over
Old 01-17-2024, 04:48 PM   #33
fishnixon
fishnixon's Avatar
Machined the block and head
Old 01-17-2024, 04:56 PM   #34
fishnixon
fishnixon's Avatar
That’s a wrap at the machine shop…
Old 01-17-2024, 04:58 PM   #35
fishnixon
fishnixon's Avatar
Back at Jim’s place…block, head and crank are all set. New cam too!
Old 01-25-2024, 11:06 PM   #36
fishnixon
fishnixon's Avatar
Back on the stand!
Old 01-25-2024, 11:08 PM   #37
fishnixon
fishnixon's Avatar
New rods and pistons, .020 over.
Old 01-25-2024, 11:11 PM   #38
fishnixon
fishnixon's Avatar
Progress!
Old 01-25-2024, 11:12 PM   #39
fishnixon
fishnixon's Avatar
In the pump
Old 01-25-2024, 11:14 PM   #40
fishnixon
fishnixon's Avatar
Oh yeah!
Old 01-25-2024, 11:16 PM   #41
fishnixon
fishnixon's Avatar
Lined up and KDP secured
Old 01-25-2024, 11:17 PM   #42
fishnixon
fishnixon's Avatar
Ready, Set…
Old 01-26-2024, 11:11 AM   #43
loudchevy
Active Member
loudchevy's Avatar
Awesome progress
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 01-27-2024, 12:34 PM   #44
fishnixon
fishnixon's Avatar
Originally Posted by loudchevy View Post
Awesome progress
Thanks!
Old 01-31-2024, 12:53 AM   #45
vk_chevy
vk_chevy's Avatar
great project! curious about new rods vs getting the old ones rebuilt?
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 02-04-2024, 02:31 PM   #46
72 tigger
72 tigger's Avatar
Cool build!
Good choice to go through the Cummins now
I have a Chevy-Dodge too. Built it in 2003 using a rolled over 02 Dodge.
I used the entire drivetrain and chassis on mine- been using it for over 20 years.
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 02-12-2024, 01:01 AM   #47
fishnixon
fishnixon's Avatar
Thanks…good question. I went with Jim’s recommendation on that one.
Old 02-12-2024, 01:04 AM   #48
fishnixon
fishnixon's Avatar
Originally Posted by 72 tigger View Post
Cool build!
Thank you, I’ve always wanted one…how difficult was it to put the Chevy on the Dodge chassis?
Old 02-12-2024, 01:08 AM   #49
fishnixon
fishnixon's Avatar
Back at it…I wanted to locate the position of the 350’s harmonic balancer vs the frame, which then I can use in locating the Cummins.
Old 02-12-2024, 01:12 AM   #50
fishnixon
fishnixon's Avatar
I also made a note of where GM locates the engine cross member and will measure the distance from the center of the mounts to the front of the balancer, and compare that to the Cummins mount location…I’ll attempt to use the Mopar crossmember and new mounts on the project.
